Problems towing a Bailey Unicorn with Skoda Superb
Oct 8, 2006
2,008
696
I'm surprised to see 'hitch limit unknown.' Bailey's for years have used the Al-Ko chassis which has a standard maximum hitch load of 100Kg.
Mar 13, 2007
1,750
hi John,
thanks for your latest additions, answers most of the questions, for reference, do your own research, and do not use weight comparison sites, as the data they use is very unreliable, that is why both the prof and I advocate ignoring them totally. how can the same car and van be matched at 87, 94, 105, and 125%, makes no sense does it!!.
I would say as I did before, the outfit should be fine if properly trimmed and set up. as you had with the morning star,
the MTPLM of that van was 1550kg and the unicorn 1565kg, so near enough not to make any difference. both of those vans are also well within the legal limits of the cars GTW, so no problems there.
I have tried to find the exact model used for the tow car test but it is not exactly the same, however a similar one won the award towing a 1500kg caravan, so it is not the cars fault.
I think you were just unlucky and got a bad day when things were not quite right, it can happen :whistle: set it all up properly as you did with the ACE and I am sure next time will be better, I certainly would not spend more money changing anything if towed the ACE, it will tow the Bailey.
Colin.
4,163
Hello again John,
Thank you for the additional information - but it raises a real question about the matching sites information. As you present it it is full of contradictions. How can the sites opening statement condemn the out fit, yet further down it praises the combination? confusing isn't it. and that's from just one site!
The fact is using the conventional tow weight ratio calculation you are running at over 100%. The industry guidance suggests this is not an ideal tow, but because it is within the car's stated towing weight limit it is technically legal.
Nose load has been called into question and that is something you need to properly address. If necessary trim the nose load by counter balancing with items inside the caravan. EU directives require: when hitched the centre of the tow ball must rest at between 350 and 420mm vertically above the ground. If it's outside these limits then it is either over or under-loaded, or the suspension and tyres of the car are not to correct specification.
In the light of your last post I am now concerned you may be in danger of overloading the car.
There is no requirement for a towed outfit to be able to achieve 60mph, so if necessary tow at a lower speed.
Sep 21, 2007
258
16
18,685
Just for info, if it helps. I tow a 2011 Valencia and the nose weight is over 100kg before loading. I have two lightweight gas bottles in front locker a lightweight porch awning over the axle a couple of folding baskets full, but not overly heavy, on the floor beside the fixed bed. The aqua roll in the bathroom at the rear and wastemaster, sat dish, ground sheet folding chairs and table under the bed. Everything else is in the car. This gives me a nose weight of 90-95kg. My car can handle 150kg and the limit for the hitch is 100kg. Never had any issues towing the Valencia for nearly 6 years. I know its a different car to the op, a Freelander 2, but I would deffinately look at nose weight. If the steering is light and knowing the nose weight is heavy from new then theres a good chance the ops is heavy too.
4,352
Jontgee,
I did read on a diffrent website, about a lad that had problems with a caravan about the same problems and after a lot of checking out it was the Alko ATC system that was the problem. It took a lot of checking but was confirmed the ATC was the problem. Try towing with the ATC unpugged and see how it feels.
Hutch
Feb 3, 2008
3,790
Before any more speculation and advice it would be useful for the OP to measure the nose weight of his van in the trim it was for the journey, and to let us know the figure.
4,163
Hello Woodlands,
I think such an exercise would only benefit us to satisfy our own curiosity,.From the OP's perspective, its more practical to start from scratch and check everything as has been described.
But like you I would like to know if our deductions are right about the nose load etc.
4,352
WC and ProfJ. You are correct, without hands on, treatment, we can only guess, So please Jongjee , come back, so we can help.
Hutch.
Feb 3, 2008
3,790
The relevant facts given to us so far are:
CAR (2.0 ltr, 170PS)
V5c Mass In Service 1562 kg
Weight Plate 1 - 2125 kg Gross Vehicle Weight
Weight Plate 2 - 3925 kg Gross Train Weight
The difference between 1 & 2 is 1800 kg, Max Trailer Weight
Max Nose Weight 80 kg
Tyre pressures set for full load
VAN
MTPLM 1565 kg
Actual Nose weight = ??
Tyre pressure correct?
Conclusions:
1. The engine should be powerful enough
2. The max weight of van (1565) is within limits (1800), unless it was overloaded
3. The Train Weight (3690) is within limits (3925)
4. The actual nose weight is unknown
5. The van loading is unknown
6. The licence conditions are OK
Jul 10, 2016
16
Hi All
many thanks for your really useful information. I will indeed start from scratch and check everything out. My dealer has kindly offered to help with me with loading, noseweight etc so I will take up his offer before I next try to tow this . I have learnt so much from all your advice, so thanks again
5,061
I am optimistic your problem can be resolved.
Poor weather is a problem for a tugger and Gaffer bill's observation is very valid.
The beauty of this Forum is that we are always learning. Getting a resolution to your problem will help others so please let us know the result.
Good luck and don't give up. :)
1,818
The combination may be legal assuming the Op has the correct licence but the towing ratio is simply too high for a newcomer and I would say not good enough even if you are experienced.
Mar 13, 2007
1,750
sorry Ray it's not, the weight ratio is fine, and well within limits, the OP, is not a novice having towed for 7 years and prior to buying this van, towed one of similar weight without issue, however changing a van if it has a different layout from the one before can have huge influence on the way it is trimmed. and loaded, I believe this is the problem.
as the saying goes "there are caravanners and then there are people who use caravans" one should not confuse one with the other. or assume everyone is the latter.
Feb 3, 2008
3,790
Please tell us what the nose weight was during your experience (use bathroom scales and caravan steps). Your dealer won't be able to tell you any more that what the experienced forum members have already told you. ;)
1,818
Colin, The towing ratio is far too close to 100% for my liking and it is not a combination I would consider. I might look at a Superb though to replace our Mazda but our Quasar has a MTPLM of 1350 which is far better from my point of view.
Mar 13, 2007
1,750
hi Ray, that is the trouble with "on paper" ratios, and one of the reasons I am totally against the 85% rule [recommendation] as so often quoted and adhered to as some sort of magic formula for towing, it is not, it assumes the complete worse scenario, empty car and fully loaded van, and uses this as a basis of making a guess of the compatabillity in the form of a percentage figure, now we are all caravanners [or was] no-one goes away in the van with it full while the car is empty, as soon as you add weight to the car and remove some from the van the ratio drops significantly a combo that is around 90% will be nearer 75% when loaded and trimmed, true the more experience you get the better a tow becomes, but even at 100% [as recommended] should not be cause for concern.
for instance I have towed the same van with 3 different cars, one at 75% [Mondeo 1.6], one at 88%[Meriva 1.7cdti] and one at 98% [Megane 1.9dti], there was no significant difference between any of the tows, in fact to be honest the 98% one was quite a bit better than the 75% one due to the size of the engine, I did however trim the outfit differently for each one. weight alone will not make or break a good tow, there are far more factors than weight that are more important.
Colin.
Oct 29, 2007
62
Apologies for coming late to the discussion, but the following might throw some light on VAG groups published kerbside weights!
My outfit, Skoda Superb mk3 190ps (187bhp) Auto 4x4 estate, Plus caravan, a Swift Challenger 580 SB ALD, MTPLM uprated to 1550kg.
How to calculate the kerb weight of your car without resorting to weighing it! as the VAG published kerb weights are entirely useless! & can't be relied on as they are based on the base spec, manual gearbox & smallest available engine of each car as delivered in Germany!
First, all VAG vehicles are individually weighed as they come off the assembly line, & in the UK its noted on the V5c (reg doc) page 2 under mass in service.
Second, find the fuel tank capacity, add the weight of fuel to fill the tank (in my case 54.91kg, as my tank capacity is 66ltrs (when they come off the assembly line there's approx 2 ltrs of fuel in the tank). Unleaded petrol = .737kg per litre. Diesel .832kg per litre.
Third. add the weight of any PERMANENTLY fixed after market accessories such as tow bar, changing puncture repair kit with spare wheel & tool kit. etc.
Lastly add 75kg for the driver, apologies if your weight is under or over that but that's the internationally recognised "standard" weight of a car driver!
So my car: Mass in running order 1635kg, fuel 55kg (as near as damn it!), Tow bar & electrics 45kg, full size spare wheel & tool kit (replaced the useless puncture repair kit) 30kg & me, a nice trim 75kg (I wish!!!!!!) making a total kerbside weight of 1840kg, difference between mass in service & actual 205kg that's 4cwt or 448lbs in old money!
If I was a novice tower then my safe MTPLM would be 1564kg, but as I've been towing for over 40 years, I consider myself to be an experienced tower, when I'm towing a caravan I try not to exceed the car's kerbside weight, but a loaded braked trailer maybe slightly more but not exceeding the car's max of 2200kg
8,693
My Superb Estate CR 170PS 4x4 requires a large increase in tyre pressure when towing. It sits on 225/45/17 wheels and I pump the rears up to 310kpa and fronts to 250kpa when the car is loaded and the caravan hitched up. Other than having its "bum" a bit near the ground it is very stable. I am also aware that when Bailey released that range of caravans there were lots of comments re the difficulty of attaining a noseweight around 70-80kg which many cars specify. And owners of theses caravans had to experiment with weight positioning to get the noseweight down. I suspect that the problem was noseweight plus a combination of other factors compounded by bad weather too. When I took delivery of my current caravan I had to bring it from Devon during bad weather in January and specifically took my noseweight gauge along with me and had to do some balancing before I ventured onto the M5 and brought the van back. Please no comments about using noseweight gauge, even a calibrated one!!! It got me home okay.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
cdqwef
