Ratchet advice required.
4,902
I have a socket set for the torque wrench and think it is 1/2 square drive. I need to access and remove the 12v aux battery. The the battery is located under the driver's seat so limited room to swing the arm. I would also need an extension at least 150mm in length. I could have it done by a local garage, but they want a £68 fitting fee.
572
456
1,135
A recent post of yours springs to mind.
I understand that, but if they are clumsy with a spanner, maybe they should not be working on a motor vehicle?
Funnily enough, that post was in relation to removing / fitting a battery. I think the same holds true for a 'numpty' who doesn't know which tools to use, or how to undo those 'bolt things'. Maybe you should let the garage do it. ;):ROFLMAO::ROFLMAO::ROFLMAO:
3,900
1,636
Something less clumsy would be my choice, plus could be used for so much else not requiring 1/2" impact driver sockets.
Like LINK
4,902
I know which tools to use, but not familiar with different sizes etc and have not come across the bolts that fit into the battery terminals. Otherwise the battery is a doddle to remove even for a numpty!
Reactions: Beardy
Nov 30, 2022
1,825
1,683
2,935
A torque wrench, to undo the battery terminals?
If you are unsure of the size then buy a small adjustable spanner!!
The nuts will not be that tight. But as other have said you are clearly not confident, or indeed competent so maybe this job is best left to someone who knows what to do? (A friend or neighbour?)
Have you looked on you tube for "How to undo a nut"?
  • Haha
Reactions: Challenger
Nov 30, 2022
1,825
1,683
2,935
Well clearly you don't know which tools to use. If you did you wouldn't be posing this question! The way to find out what size the nut is, is to try various sizes of spanner or socket, one one them will fit. Probably somewhere between 10 & 14mm. Or even simpler an adjustable spanner! It's a bolt or a nut, they all undo in exactly the same way ( it's anti-clockwise)
3,900
1,636
It appears it could be a simple nut & washer or possibly be a washer nut, one with oversized hex [M10] but on a light M8 stud, most likely with the nut made of brass, given its application and relative quality of the vehicle brand.
This is not a job where 1/2" drive would be the tool of considered choice; as already stated if using a socket set a 3/8" drive would be used. There is no direct need to consider a ratchet.
Or if careful and the job is procedurally done correctly a ring/combination or open ended spanner could be used.
4,934
The blown up photo centre of the nut looks like a Torkx male.
Like JTQ I’d be using a smaller kit. My 1/4” drive set would do the job. But be sure you don’t drop anything and lose the fixings.
4,210
It seams to to be, a case of, take it to a dealer.
Torque wrench, 3,/4 inch drive. . You Do not know what you are doing. Sorry to be blunt. But as you can be with others , normally with your posts that is how it is.
Numpty.
4,210
No you don't know. I am surprised The Prof hasn't jumped in about safety and batteries.
3,900
1,636
Is it even a "bolt" or is it a "nut" on a stud, the depth of the hex looks too great for what is typically seen in bolt heads?
However, being a heavy current electrical application then good practice is the use of softer brass nuts, where the nut depth is elongated reflecting this weaker material.
These aspects ought to be self evident though not too clear in the furnished photo.
The nut or bolt head has no machining to indicate it being left handed, as it would, nor does the application support such a case.
3,900
1,636
Remember those. On some Ford transits wheels.
There for sound reasons, not quite what we see with battery connections!
[would you expect the positive or negative to "need" LH , or both if the vehicle had a reverse gear? ;) ]
4,210
Talking of Numpys, Son turned up on Driveway, New car, he doesn't know where the wheel key Perrelli Scorpion on a New Defender.
3,900
1,636
Talking of Numpys, Son turned up on Driveway, New car, he doesn't know where the wheel key is, flat tyre.
As we used to say "Read the ******* handbook", then these days even that basic skill passes many by.
Show him the tangentially placed cold chisel technique ;)
4,210
I know, he is a design engineer for JLR, exhaust, intake and battery compartment, , but Common Dog Fxxx.
Love him to bits can't turn a spanner.
Reactions: Mr Plodd
Oct 19, 2023
572
456
1,135
Used to be common on the near side hub nuts on most cars. Not sure if it's still the case as I haven't changed a wheel bearing for years and the last one I did came as a complete assembly. I do remember a work colleague getting one off with a 1/2" socket, T bar and 4 ft scaffold pole (new hub needed afterwards).
  • Haha
Reactions: Dustydog and Hutch
2,475
I have a socket set for the torque wrench and think it is 1/2 square drive. See pictures. I need to access and remove the 12v aux battery. I don't think I could use the torque wrench as it maybe too long. The the battery is located under the driver's seat so limited room to swing the arm. I would also need an extension at least 150mm in length.
I could have it done by a local garage, but they want a £68 fitting fee. I would appreciate some advice on ratchet size as a bit of a numpty in this area. Also those "tower" or bolt things that screw into the square terminal points, are they easy to remove?
View attachment 8079View attachment 8080
Not sure if you are trying to remove the terminal or a battery cover, or both. Does the seat need to come out. What is the square drive bolt for.
If you are trying to change the battery I think Halfords do it for a fixed price around £25.
