Hi all,
I have a 1993 Swift Corvette Diamond, with a standard Truma water inlet (old style, not cartridge) and 12v whale water pump. The van is powered by an Amperor products 3 stage leisure charger, which replaced the standard built in swift charger which was faulty when we bought the van 4 yrs ago. It was professionally installed by the dealer, and appears to be working absolutely fine.
My query relates to the 12v circuit for the water pump.
Whilst preparing the van for our first trip away next week, I was preparing to sterilise the water system, but the pump would not operate. I did a few checks, and found that the 12v on the battery pole had worked loose, so repaired that. I re-checked, still no pump operation. (this was just fortunate I found this)
I then checked the voltage at the pump socket, and this is where I have my query.
With the amperor turned OFF, therefore only on battery, the pump circuit is at zero volts. When I turn a tap on, 13 volts....... this is exactly what I would expect. (disclaimer - I am NOT an electrician, only a keen diy`er)
With the amperor turned ON, the pump circuit is fluctuating between 6 and 7 volts, and when I turn a tap on, it goes to a solid 13 volts.
I have never, to my knowledge, had occasion to check the residual circuit of the socket with the amperor on, so could not honestly say if that residual 6/7 volts is normal, HOWEVER (and here`s the surprise) my fault finding diagnosed a jammed pump, and after freeing it off, the pump operates fine....... and when plugged in, everything works exactly as it should....
So, had the pump not jammed, I would have been unaware of the residual voltage, and this could be absolutely normal.... but now I know about it, I need to make sure it is safe....
Its like a countdown conundrum.......
Any words of wisdom from people far cleverer than me ??
