We're on a seasonal pitch and intend on visiting every couple of weeks or the occasional night, should we drain the water down each time, or just at the end of the season.
I’d drain down.We're on a seasonal pitch and intend on visiting every couple of weeks or the occasional night, should we drain the water down each time, or just at the end of the season.
Hi, I'm not sure which heater/boiler it is I forgot to look, it is a truma controller.It also depends what heater you have, Alde say you should drain off about 20 seconds of water every (I think) 3 weeks to maintain the air cushion in the fresh water side of the heater to stop hammering as the air cushion gets reduced, I would guess it would/could probably be a good idea if you have a Truma combi to 🤔
I would drain down for the peace of mindWe're on a seasonal pitch and intend on visiting every couple of weeks or the occasional night, should we drain the water down each time, or just at the end of the season.
Thanks all, I did drain down both times I've left, I stayed overnight while I puricleaned the pipes I left it in the system for about 17 hours, and then we stayed 2 nights over Easter, I was just surprised how much water came out of the drain down pipe, is it best to capture this in the wastemaster or just let it hit the turf.
Thanks, it was plain water, all the puriclean went into the wastemaster.If it’s got steriliser in it I would capture it. But plain water can drain onto the turf without detrimental effect.
Thanks good advice, with a house the water is coming in off the mains open the tap let it run and there is no standing water issue.The fact you have asked the question suggests your possibly concerned about the safety of water left in the system, and that is a wise concern.
There definitely important reasons to drain down in winter conditions, as freezing can seriously damage parts of the water system. However at other times of year, whilst the danger of freezing has gone, there can be other legitimate concerns:
It's not a fair to compare the conditions in a normal domestic house and a touring caravan. The mass of the bricks and mortar of a house tends to moderate internal temperature swings, whereas the mass of a caravan is far less so thermal gain and loss is still several times greater leading to quicker and bigger temperatur swings inside the caravan. This will affect the pipe work.
Also the type of pipework is very different and being flexible it means the internal surface is not as impervious as the harder PVC piping used in domestic installations. The softer/flexible wall construction can become a breeding ground for contaminants.
Normally contamination is not a major issue in touring caravans, but you have to remember most caravanners will drain the water system before travelling, and certainly reduces the risks.
Leaving standing water in for a fortnight I think could be tempting fate. I advise draining.
Wastemaster? I mistakenly thought your seasonal was a FSP.. Agree with Clive , not on the turf!Thanks all, I did drain down both times I've left, I stayed overnight while I puricleaned the pipes I left it in the system for about 17 hours, and then we stayed 2 nights over Easter, I was just surprised how much water came out of the drain down pipe, is it best to capture this in the wastemaster or just let it hit the turf.
??Wastemaster? I mistakenly thought your seasonal was a FSP.. Agree with Clive , not on the turf!
You've misunderstood what I meant, when I did the puriclean all the water went into the wastemaster.Wastemaster? I mistakenly thought your seasonal was a FSP.. Agree with Clive , not on the turf!
We let the water from the boiler drain onto the turf. The boiler would have been switched off in the morning. On board tank water goes into drain, but could go onto the turf as it is clean however then the next person using that pitch would have a soggy pitch.You've misunderstood what I meant, when I did the puriclean all the water went into the wastemaster.
When I leave on any given stay should I capture the water from the drain down pipe into the wastemaster or just let it hit the turf.
It's a grass seasonal pitch.
Leaving the pitch the water in the system is just clean water so you can discharge it onto the gravel or turf without detriment. As you said earlier your sterilisation water went into the Wastemaster which is correct practice.You've misunderstood what I meant, when I did the puriclean all the water went into the wastemaster.
It's my pitch, no one else uses it.We let the water from the boiler drain onto the turf. The boiler would have been switched off in the morning. On board tank water goes into drain, but could go onto the turf as it is clean however then the next person using that pitch would have a soggy pitch.
It’s a grass seasonal pitch for the OP. Soggy pitch through draining the water down isn’t really an issue to be concerned about.We let the water from the boiler drain onto the turf. The boiler would have been switched off in the morning. On board tank water goes into drain, but could go onto the turf as it is clean however then the next person using that pitch would have a soggy pitch.
I was referring to our circumstances as I am aware that you are on a seasonal pitch.It's my pitch, no one else uses it.
My van is permanently sited there all season.
I assumed as a seasonal you had a fully serviced pitch and wouldn’t need the Wastemaster. I agree run the puriclean into the WM not dumped onto your grass pitch.You've misunderstood what I meant, when I did the puriclean all the water went into the wastemaster.
This is giving slightly mixed messages. Do you mean you own the pitch? or are you renting it.?It's my pitch, no one else uses it.
