Sensitive TPM,s
3,700
My VW is finite per tyre. The warning below 33 psi is a visual and initial gong. So very sensitive and I’d say well done the engineers getting it to do what it should so accurately
My Touareg isn't so sensitive - the monitor specifies 2.3 bar (33 psi) but doesn't trigger at 2.2, only if it drops to 2.1 - mind you the sensors are over 10 years old compared to a nominal battery life of 5 years.
4,648
I. Think my 2014 Santa Fe , is the same, Normal tyre pressures are 33, and TMPS warns ast 30 psi. A sensible drop.
640
396
19,135
The Kuga gives the pressure readings of all 4 tyres so you can see which one is low if warning comes on. So I pump all tyres to the pressures required back and front and then in the menu press set to store them. So if I need the rears a bit higher I put extra pressure in them and then in the menu do a set again to remember them. If one gets low the display shows which tyre it is. Previous motors have needed checking every tyre with a gauge to find which one was causing the warning.
Reactions: borderbilly
Feb 13, 2024
1,393
884
1,435
My kia is the same.
5,360
On the Lexus and also Landcruiser up to 2021, you cannot see the individual pressures. All you get is a warning that one of the tyres is low pressure. I believe this recently changed as the 2025 Yaris shows individual pressures. On all my Jeeps from the 2005 model until the 2018 model individuals pressures were shown.
4,090
1,814
The sensitivity resulted in you correcting an underinflate tyre, that would be it doing its job to me and that I would be pleased with.
5,428
I guess it all depends who when and where the original calibration was done?
I’ll get some photos in the next poor weather
Jun 6, 2006
981
223
19,135
I use Tyre Pal sensors, I set the last winter, they went up in the summer, they have been fine, couldn’t be bothered with adjusting daily/weekly/monthly, I just adjusted upper and lower limits, they were still within the tyre specs for the vehicle they are fitted on
3,700
Fred Drift
, are you on the oem battery? I am and have a gut feeling this winter may be its last🙀
No - I changed the main battery at 8 years old - but when I tested it it still had about 60% capacity - unlike all my previous "old" car batteries I couldn't use this in the caravan as it was too big to fit the battery box so gave it my son for his camping trips.
