- Feb 13, 2024
- 957
- 604
- 1,135
Lidl have the above in for £2.99. I. Have used this before and can't fault it.
Thanks, I need a couple of tin.Lidl have the above in for £2.99. I. Have used this before and can't fault it.
Lubrication (awning rails, toilet cassette seals, window ans door seals......)With apologies for my ignorance, what is silicon spray used for, please?
Great for things that are sticking a bit like the catches on lockers. We use it often.With apologies for my ignorance, what is silicon spray used for, please?
In their wide product range WD 40 do sell silicone spray ........I've got an aerosol in the garage, but not at Lidl price unfortunately.Great for things that are sticking a bit like the catches on lockers. We use it often.
(Not oily like WD40)
Graphite spray, to add to your confusion is good for door locks, as it PTFE spray, both dry to a NON oily lubricant.Lubrication (awning rails, toilet cassette seals, window ans door seals......)
Thanks for all the replies. I have a can of it that I use for the toilet and tank draining taps. Never having had an awning, I hadn’t thought of that option. Will bear it in mind. I thought perhaps there might be further uses of which I was unaware.Lidl have the above in for £2.99. I. Have used this before and can't fault it.
That a great price from ScrewfixIf Lidl don’t have any Screwfix have a 200ml can for £3.19 or a 750ml trigger bottle for £6.50.
Yes that’s fine.When I open my outside lockers, it says to periodically treat the rubber with silicone - do I just spray it on and rub it into the seal
If there is a chance of overspray reaching the surrounding paintwork, I would face away from the caravan and spray some onto a sponge , then wipe the sponge around the seals to transfer the goodness.When I open my outside lockers, it says to periodically treat the rubber with silicone - do I just spray it on and rub it into the seal
