- Jun 16, 2020
- 5,464
- 2,417
- 11,935
Is yours an M Hybrid model?I did a bit more digging, and this description does feel like it represents how my Mazda behaves, so fuel injection rather than using the starter motor:
While conventional idling stop systems rely on a starter motor to restart the engine, Mazda's i-stop restarts the engine through combustion; fuel is directly injected into a cylinder while the engine is stopped and ignited to generate downward piston force. The result is a quick and quiet engine re-start compared to other systems and a significant saving in fuel.
To restart the engine by combustion, the compression-stroke and expansion-stroke pistons need to be stopped at exactly the correct positions to create the right balance of air volumes. Mazda's i-stop ensures precise control over the piston positions during engine shutdown. With all the pistons stopped at the optimum positions, the system then identifies the initial cylinder for fuel injection. It injects fuel and ignites it to restart the engine. Even at extremely low rpm, cylinders are identified for sequential ignition, making the engine quickly pick up to idling speed.
These technologies enable the system to restart the engine with exactly the same timing every time, to enhance fuel economy, and to deliver smooth and comfortable acceleration for the driver at restart. The restart takes place in a mere 0.35 seconds (internal measurement on vehicle with automatic transmission), which is about half of the time taken by conventional starter-motor idling stop systems.
