Swift Challenger Replace Microwave
Dec 24, 2023
14
I have a Swift Challenger 560 2021. The microwave stopped heating which suggests the magnetron has failed. I have sourced similar models that I can buy at a lesser rate than from Swift but I am struggling to remove the old. I can removed the panel above and the method is supposed to lift it up and out but I am finding it difficult to lift it level to get out of the cavity. I don’t want to damage the wood at the bottom. Any suggestions?
Jun 16, 2010
388
169
18,735
On mine, it was a case of removing removing the top panel (there are screws hidden behind stickers in the inner panels either side of the microwave).
Then pull out the wooden shelf thing that sits above the microwave (its a tight fit). Microwave then lifts up and out
Dec 24, 2023
14
Then pull out the wooden shelf thing that sits above the microwave (it’s a tight fit). Microwave then lifts up and out
Excellent that makes total sense. Thank you.
Dec 24, 2023
14
Managed to get it out thanks. What doesn’t make sense though is the manual states the dimensions as 595x343x382 but the microwave is smaller than that and the cavity too. I am looking to buy the recommended replacement Cookology IM20LSS which also has the larger dimensions in the manual!! Totally confused
Jun 16, 2010
388
169
18,735
Think its going to be a case of measuring the old one, then popping down Currys and seeing if you can find something similar.
The alternative is not cheap
Dec 24, 2023
14
Spoke to Cookology. The measurements include the fascia. He said it’s the third same query this week. Don’t feel so daft now. Thanks for the reply
Jul 3, 2024
Just followed this thread and have successfully fitted a replacement microwave to my 2015 Swift Conquer 480.. Thanks for ordering information and a comfortable feeling regarding compatibility and sizes..
03/07/2024...
Regards
Ke n...
Reactions: littlebasher
Aug 5, 2024
9
510
03/07/2024...
Regards
Ke n...
On that note, we've just bought a swift challenger 530se, & the microwave is dud. Looks like the same one used in the 2015 Conqueror. It has no branding (even on the back). Is the cookology one mentioned above a direct replacement, & fits straight in please? Thanks
Jul 3, 2024
I would suggest it would be exactly the same as the one I removed, I had to remove a base plate and modify the four feet to accommodate for height restriction but very simple to do....
Ken R
Aug 5, 2024
9
510
Ken R
Thanks Ken. Really sorry for what might seem like daft questions, but we are fairly new to this. Is the base plate the two strips of wood with metal over them (that the feet of the microwave drop into), or a baseplate on the actual microwave. Also, what mod did you have to do to the feet of the new one please? Thanks
Jun 6, 2006
1,008
234
I replaced one, I swapped the feet over from the dead one to the new one as the new one had longer feet. Other than that it was a doddle, less than 10 minutes
2,649
When our microwave pack up our Abbey we replaced it with this Daewoo 700watt microwave oven it fitted like a glove but seeing i am not handy my caravan engineer did for me . but good luck if you can .
Aug 5, 2024
9
510
Thanks. Will get one ordered & see how we get on then 👍
Ordered the microwave & fitted it this morning. Fits perfectly & was very straightforward. If considering it, don't throw any parts away until your new one is in. The new fascia plate supplied was far bigger than our existing one, so the old one went back on. Feet also need swapping. Thanks to everyone on the forum who gave advice on this - without it, probably wouldn't have had the confidence to attempt this swap out 👍
5,445
What brand microwave did you eventually decide to buy?
Aug 5, 2024
9
510
Hadn't really heard of Cookology until looking at the forum, but tested it & it seems ok. Looks identical to the old one tbh 👍
