Chicken !!!!!?????
One who is crossing the road to get away from the dreaded but ultimately futile noseweight debate. 😉Gabsgrandad said:Chicken !!!!!?????
Dancing with the Devil Hutch 🤢 😱hmy: :evil: :evil:EH52ARH said:Prof, I can only see, the nose weight changinging, with height of the tow hitch , if you have a very high C of G directly over the axle. And normally only on a caravaan with a short wheel base.
Can explain to me why , the hitch hight changes the nose weight, please.
Hutch.
Hutch.
ProfJohnL said:Thank you Chrisn7 for your last post. I was particularly pleased to see that you have to do a calibration process and made a point of ensuring the JW was always castered in the same direction. I know this is important and it is good to read that Alko who supply the Premium JW also recognise the importance of this vital consistency.
But a point you raise in your post about the commercial available processes being enough and all that we can do, is worrying. If we consider a case were you are accused of speeding, and you claim your speedometer showed you were not speeding, it would not be accepted, as speed limits are absolute and it is your responsibility to ensure you remain within them regardless of the equipment you use.
The same principal applies to vehicle weights and loadings. Not withstanding Parksy's reservations about there being no reports of nose load prosecutions, that does not mean there have been none, it could just be they've not been high profile enough to warrant press attention, but also it highly likely that if a nose load transgression is detected, its usually a relatively simple matter for the driver to rearrange the load within the caravan to correct the situation, and will probably just warrants a warning/caution and not taken to prosecution.
If you don't know the inherent error of measuring equipment, then you can't know how much to allow for its inaccuracies.
Can explain to me why , the hcitch hight changes the nose weight, please.
Hutch.
Gabsgrandad said:Just as you explained it to me Parksy!
There you go then. My entire comment is mildly sarcastic, this sort of lengthy irrelevance happens whenever a fairly simple question is asked by an unsuspecting newbie, but to keep you happy I've removed the words that are so upsetting for you.pitpony said:Parky,
Do you realise that according to Damian the Mod that the term 'Nose weight Police is a sarcastic comment 🙂
xtrailman said:...
Its not easy at first as you don't feel back loading is ideal, but in practice its never been a problem regarding stability...
