Climate control is more than just automatic temperature adjustment - it will also control the humidity, the distribution of the air within the car and the air re-circulation/ fresh air depending on air quality.Is that not what "climate control" does?
You set the temperatures you like for driving, and the front seat passenger individually like, say in wintertime and the AC system goes about achieving that, putting the cooling or heating and blower systems into "overdrive" to get you there ASAP and then settle down to maintain it, irrespective of the ambient.
The only gripe, not from me, but "we" have, is on leaving home etc the fan is so noisy for a while that the radio can't be heard.
The end result is set and forget, at least season for season, whereas with basic systems you make and set the controls, and have to reset them intill there is a steady state situation, though that can change if the ambient does; IMO involvement that technology can readily take on.
I have had a few cars now with AC and really cannot call it a hassle to control. In one of our current cars if it’s a cold day or rainy the vent gets put to screen, ac switched on, fan switched on to a higher setting than normal, heater to hot. When everything has stabilised fan turned down, vents to face and floor, aircon left on. What’s the hassle? It’s not that long ago that many would have given their all just to have aircon in a car.Yes, all tasks that if not done for you in the background you either forgo or attempt to fiddle about achieving; the hassle with my wife's Golf I don't like.
Only yesterday I was informed that our Jeep had a deadlock system that cannot be disabled. Apparently it deadlocks when locking up the vehicle and not when driving. Not too sure about the deadlock?I'm convinced my Volvo has lots of "stuff" that I simply haven't discovered! The drivers-profile bit is one area that I simply haven't explored, apparently it saves my own driving style and adjusts characteristics of the car to suit my sedate approach to driving. I love cars and I like technology, but sometimes it just seems like there's either too much of it or I don't have enough brains/patience to understand it!!! 🤣
I had a 2016 BMW520D and while we were away on holiday we went to a supermarket in Brighton. My wife and daughter stayed in the car while I went into the store and out of habit I locked and deadlocked the car on leaving. It was impossible for them to open the doors from within and they ended up phoning me in a bit of a panic as they'd set the alarm off through moving inside but couldn't get out. It was in the manual about this but (typically) I hadn't bothered reading anything on the locking system as that was one of the easy bits of the car to understand (or so I thought....).Only yesterday I was informed that our Jeep had a deadlock system that cannot be disabled. Apparently it deadlocks when locking up the vehicle and not when driving. Not too sure about the deadlock?
The idea that you can effectively set different temperatures for driver and front seat passengers is laughable.Is that not what "climate control" does?
On our old Volvo you locked on the fob and after a couple of minutes the deadlocks would click in.Isn't the locking and deadlock system, where you lock the car by the remote key fob, but if you use the key to open the doors, the engine is still immobilised.
Or is it something else new.
It does work, and quite efficiently as well,. At least on Our last 5 cars. 2 Santa fe's and 3 Vectra.'sThe idea that you can effectively set different temperatures for driver and front seat passengers is laughable.
How far apart are you sitting? Different temperatures at a couple of feet, at most, apart.
Just can't see that working somehow.
I don’t know to be honest, I do know it caused a bit of a panic though! I believed that even when deadlocked there’d still be some sort of emergency release inside but there wasn’t (other than breaking a window!)Isn't the locking and deadlock system, where you lock the car by the remote key fob, but if you use the key to open the doors, the engine is still immobilised.
Also handy to do that if you go up on your garage roof to check for a leak and accidentally knock the ladder over while up there. I have the T-shirt on that one...........I did take my phone with me incase I couldn't unlock it with the remote. So I could call the wife.
You may not believe it but it does work reasonably well in my VAG Passat. When there is no passenger, it disables the footwell and cabin heating on that side whilst maintaining a controlled temperature around the driver.The idea that you can effectively set different temperatures for driver and front seat passengers is laughable.
I spent ages when the car wouldn’t lock either by its keyless facility, by using the fob or even the mobile Kia app. I got back in, restarted the engine, switched off and got out. But no joy it wouldn’t lock. Then I realised my wife had left her handbag in the footwell. The presence of the spare car key was preventing me from locking the car.Just tried it in my Santa Fe, sat inside it and locked the car, 30 seconds later another little click , and I am stuck, NO handles working to get out.
Every day is a school day.
On the Citroen too, although it does recommend in the user manual that there shouldn't be more than a couple of degrees difference in the settings between the two sides. I guess if Mrs Gozza set her side to "tropical" and mine was "arctic", (a likely combination), we could end up with a weather front down the middle of the car and a thunderstorm over the coffee cup holder. Which wouldn't be good.You may not believe it but it does work reasonably well in my VAG Passat. When there is no passenger, it disables the footwell and cabin heating on that side whilst maintaining a controlled temperature around the driver.
Reminds me of story about guy working on roof. Wife insisted he wear safety rope, which he tied to cars towbar. While working on roof wife decided to go shopping, he survived but spent bit time in hospital.Also handy to do that if you go up on your garage roof to check for a leak and accidentally knock the ladder over while up there. I have the T-shirt on that one...........
