It was used to test for fit in addition to their own stress testing etc.I agree that smaller companies with lower overheads and less costly advertising budgets should be able to produce a cheaper towbar of similar quality.
Unfortunately we are not able to compare specifications and even the old chestnut towball heights.
In these days of consumer groups its time that proper league tables of specs were available.
Possibly a career move for someone with a head for figures like Lutz or scope for "Which" magazine!!
As for some companies they save a lot on development costs by copying a type approved towbar and then testing their copy.
This happened to me as my X was used to test the new copy and then they fitted the bought in one to my car.
Thanks David, that is useful information. My Vectra is the SRI150 estate, "02" model (petrol), how do you rate the Vectra as a tow car? I have heard that wheel spin can be a problem, I have previously only towed with rear wheel drive.Hi Jim & Pauline,
I fitted a Towequipe bar to my Vectra Estate early last year and found it to be of comparable quality to Witter,instructions OK, very easy to fit, electrics and relays fine and 20-30% cheaper than the oposition.
My car is not the current model so I can only speak about that but found installation easy as Vauxhall provide a connector in the boot for the wiring and a spare fuse position for the power supply to the split relay. The Vectra Owners club website "how to" proved helpful in advising on the brake light warning relay and rear foglight isolation. Took me about half a days work to fit a dual plug bar with assistance from a Haynes manual for the wiring codes. You may be lucky and find your car has a bulb fitted in the trailer repeater on the dash - mine did not and removing the trim to access is a pain so I fitted the buzzer suplied with the kit which again was easy.
Go for it Towequipe are OK
Mines an 2000 x reg 140 SRI Estate with LPG and if I'm honest it's not a good towcar for the very reason you are worried about - front wheelspin. I cannot get a van out of my storage site in the wet with the Vectra and damp grass on sites is always a problem. Power and torque is good however and onroad towing is great - I towed a Senator at 1330kg but if you are faced with grassy fields or sloping tracks it's dodgy - a lighter van may improve things. Traction control is no good when towing either, I found that it just brakes the spinning wheel and stalls the engine eventually - sorry to be gloomy, execellent sporty car otherwise though. I have now got an old 4x4 and a bigger van so don't tow with the Vectra - keeping it though as excellent otherwise and cheap to run on LPG.Thanks David, that is useful information. My Vectra is the SRI150 estate, "02" model (petrol), how do you rate the Vectra as a tow car? I have heard that wheel spin can be a problem, I have previously only towed with rear wheel drive.
Thanks---(I think)! JimMines an 2000 x reg 140 SRI Estate with LPG and if I'm honest it's not a good towcar for the very reason you are worried about - front wheelspin. I cannot get a van out of my storage site in the wet with the Vectra and damp grass on sites is always a problem. Power and torque is good however and onroad towing is great - I towed a Senator at 1330kg but if you are faced with grassy fields or sloping tracks it's dodgy - a lighter van may improve things. Traction control is no good when towing either, I found that it just brakes the spinning wheel and stalls the engine eventually - sorry to be gloomy, execellent sporty car otherwise though. I have now got an old 4x4 and a bigger van so don't tow with the Vectra - keeping it though as excellent otherwise and cheap to run on LPG.
