Vin Plate, Where is it?
We only had our X Trail 2.2di Sport for 5 weeks now been very please with it, but had alook at the handbook to find the vin plate, it no where under the bonnet or in side the car by the seat? if you got one of those where is it please.
Thanks Trevor
3,215
The VIN plate is increasingly found on the driver's B-post rather than under the bonnet.
The visible VIN and bodyshell stamped only have the VIN number.
The VIN plate has Maximum Authorised Weight, Gross Train Weight, Front Axle Maximum Load, Rear Axle Maximum Load as well as VIN number, paint codes etc.
Jul 15, 2005
2,175
The A post (or pillar) is the windscreen surround and front-door hinge. The B post is where the front door ends / rear door starts. And the C post is where the rear door ends.
Aug 29, 2006
291
If it not on the post look on the floor just inside the drivers door there could be a small panel there that comes off.
Will
Mar 10, 2006
3,274
47
The VIN on my 2004 xtrail can be found be moving the drivers seat back. It on the floor under the seat towards the front, under a flap
3,215
All current vehicles should have THREE VIN number locations.
The VIN should be indelibly marked on a non-replaceable part of the bodyshell.
The VIN should be visible, through the windows from outside the vehicle, and be attached to a component not easily replaceable.
The VIN should be on the VIN plate, together with required weight information and details of manufacturer, in a defined location, usually the bonnet slam panel or the pillar at the rear of the driver's door.
880
ps: The VIN number visible from outside is only applied on vehicles for the UK and North American markets.
