waterhog filler dustcap
Oct 14, 2014
Hello one n all, does anyone know if n where I can get a dustcap for my waterhog barrel, the cap has an opening of 96mm o/d, just need to be able to thread my pickup pipe through the hole n keep bugs etc out,the aquaroll type`s are too small n keep sliding off
Apr 7, 2008
4,909
The waterhog brand was made by pyramid caravan accessories who, unfortunately closed in 2011 the width of the cover you require is 105mm but they are very elusive to find, the W4 one will fit inside the neck now weather it will stretch over the top and stay in place i can't answer that .......
You can see that it is a stepped design to fit the large hole....
1,812
I believe these were imported complete and spares were not available as standard. If you have to replace it I would go for Aquaroll as although they cost a bit more all parts are readily available so the loss of a cap is not fatal as it is with some other makes.
