Wheel lock purchase
Sep 4, 2011
660
409
19,135
I have both. Prefer to use the Alko hub lock as feel it is the most secure and insurance require it. But if having to use a ramp to level when on a site pitch and the wheel will not line up with the receiver I use the other lock on the offside wheel.
PS, if you buy a second hand Alko make sure you have the registration with it, so you can transfer to yourself. If not and you loose the Key Alko will not assist you for a replacement.
Jan 20, 2023
1,310
1,167
2,435
Alko are very secure but can be awkward to fit. I use a Milenco on site but would have preferred a Nemesis at home in hindsight. As already said, check to see if your insurance has a preference stated.
9,331
Is it a good idea to buy a second hand Alko?
Why not? I bought second hand Alko lozenge and then the lock set separately. But I made sure that the lock set had been de=registered first so that I could then register it with Alko. But when touring I used a lighter Milenco wheel lock. Far less fiddly than Alko. But these days I would buy the Nemesis or Milenco equivalent and use that when touring and at home/storage.
Dec 27, 2022
667
474
5,135
When I got this van it had Al-ko fitted, registered* to the previous owner. I bought an unregistered lock barrel from eBay and sold the registered one the same way. Cost me about £10.
* Whom I was unable to contact to get it deregistered.
Nov 30, 2022
1,999
1,900
I have an Alko lock and a No39 Lozenge for sale! (Bailey Phoenix)
The lock has been deregistered (email to prove it) and has two keys plus all the paperwork and the registration card with the vital number on it.
PM me if interested in either.
2,628
If the Nemesis is easier to fit that one might be ideal if we are seasonal or in storage but we are not touring so do not need a Milenco wheel lock . but you go what your choice a Alko lock and lozenges.
2,628
My new caravan comes with Al-ko wheel lock I have been told they easy to fit and someone else , says they can be hard , I see if the dealer can show me how it goes on when he drops it off at site.?
5,362
If they are dropping the caravan off for you, why not get them to fit the lock. Easier for them to fit it than you so make it their problem.
9,331
If you have a mover they are easy to fit as you can alight the wheel with the chassis receiver by very small incremental movements. You know you have got it right when the bolt screws in very easily.
PS overtime the caravan can settle and this may tighten the bolt. So when going to take it off if it’s tight again just a slight touch on the mover will ease it off. Do not force it.
1,999
1,900
Just be sure tgat any lock you decide to use meets tgecrequirements of yiur insurance company. Some insist on using an Alko lock. They can be a bit fiddly, but tjey are not that difficult to use.
5,362
The AWS service technician will be doing that once a year so should not be an issue.
2,628
Hi Clive that what I would like do try the motor mover you have said the same thing what my caravan engineer said you got alight the wheel thanks for your input very much appreciated 🙏
2,628
Actually just took a caravan insurance out and this one wanted Hitch lock and Al-ko that meets there requitements 🙏
Sam Vimes
2,725
2,194
12,935
Might be a bit tricky if you have to use a leveling ramp.
I just went for the Nemesis. East to fit in any position and less faffing about in my opinion.
9,331
That would be my first choice if I had to fit a decent wheel lock. I only used the Alko at home or if at storage. But did carry it in case things changed on a trip. On site I used a lightweight Milenco.
3,721
It's sod's law that a levelling block is usually needed on the nearside, the same side as the Alko - but I've got used to the routine of levelling using a ramp and then adjusting the wheel forwards or backwards using the mover - it doesn't affect the levelling much.
I do have a Bulldog Titan wheelclamp from the previous caravan but it's so much heavier than the Alko so I don't bother with it.
5,446
BB,
Will your disability allow you to get down low and attach/ remove the Al-ko lock?
If the site is not level use a metre length timber board , 25 mm thick. I carry four giving me a 100 mm differential. Follow Clive using the mover for alignment.
Sometimes I have to Jack up my TA to align the two wheels.
Here at Carnon Downs I see the wardens removing and siting caravans onto Seasonal pitches. Some only stay on site for a few days. I suspect the people running your new site will do all the fetching and carrying for you. Just be certain to tell them in writing what you expect them to do regarding levelling and all the security .
Hope it all works out for you.
9,331
