Wheel torque settings
Feb 15, 2020
28
535
Thanks otherclive, I can't see there would be much changed from 2013 to 2015.
8,533
As you had a 2013, what was the advised Tow Ball weight?
The caravan Alko stabiliser hitch was 100 kg max but the limiting factor was the nose weight applied to the car towball and this was 80 kg. maximum.
Reactions: Joe M
Feb 15, 2020
28
535
Thanks again. I have a Kuga and it's hand book states 90 kgs and swift say 100 kgs, so 80 kgs sounds good to me.
Thanks again.
8,533
Thanks again.
You need to understand that there are two limits. The caravan chassis through its hitch load has a maximum. The car via its towbar also has a maximum. Swift do not get involved with the loading onto the cars tow bar only the loading onto the caravan. Ford set the cars limit. So in your case the prevailing limit for the outfit is the cars 90kg.
Reactions: DaveA1
4,939
We always like to have the caravan nose weight as close to the maximum figure i.e. 90kg if we had the same vehicle as the OP as it feels like a better tow. Our current caravan is rated for 150kg and we have the caravan nose weight at 145kg for a comfortable tow.
Reactions: DaveA1
Oct 17, 2010
1,300
545
19,435
We always like to have our caravan nose weight as close to the maximum figure i.e. in this case 90kg as it feels like a better tow. Our current caravan is rated for 150kg and we have the caravan nose weight at 145kg for a comfortable tow.
???? Are you talking about the OP nose weight or yours i e 90kg ?
What is your current car nose weight?
Sorry I don't understand!
1,818
Swift should have the 2015 manual on their website. I did try to access it, but it did not seem to be working at the moment. You need the year only as the manuals cover all models for the year.
8,533
It does muddy the waters but the OP car can take 90 kg and the caravan max is 100 kg. So lowest prevails.
