So we should spend a lot more cash on something that is inferior technology, but lauded as improved technology?
I am not sure I understand what you are getting at here. Wind turbines are high technology items. Perhaps you are referring to their lower individual output when compared to say a combined cycle gas turbine generator?
We are already damaging the future environment with wind farms as the blades which have a limited lifespan cannot be recycled at present.
That is not strictly true. Yes there is an article that is showing blades ending up in landfill, but there are lots of articles that debunk this.
While wind turbine blades are often disposed of in a landfill at the end of their life, recycling technology technically exists to process them.
eu.usatoday.com
Siemens are producing recyclable blades, and EDF are using them
Siemens Gamesa makes real what matters by engineering, building and servicing onshore and offshore wind energy to deliver clean power for generations to come.
www.siemensgamesa.com
France have a mandatory recycling policy.
The first wind turbines to be installed on an industrial scale, back in the early 2000s, are gradually reaching their end of life. Many of these turbines will be removed from the network over the coming decade. What becomes of them at the end of their lifecycle? Can they be recycled?
www.engie.com
We should also remember that wind turbines have a design life of 25 years. That does not mean they stop working on year 26 day 1. It just means that their projected life is reached, and any further use may required additional servicing. Think of it as a petrol car that is 25 years old with say 200,000 miles on it. That is way beyond its design life, but it can be kept going with regular servicing.
The same is also true for gas generation plants. They have a target lifespan of 30 years. After that they may or may not be decommissioned and recycled.
If you want to understand the mindblowinly large amount of emissions from from a gas CCG plant, they produce of the order of 500g of CO2 per kWh of energy generated. This is for a 505MW plant, operating for 75% of it's lifecycle. So in kg, 0.5 * 505,000 * 24 * 365 *30 * 0.75 = 49,767,750,000kg of emissions. That is 49,767,750 tonnes. Yes - nearly 50 Million tonnes.
If one wind turbine weighs 300 tonnes and generates up to 2.35MW, you would need perhaps 250 to support the same as one gas generator. Thats 75,000 tonnes. Or of the order of 1/1000 of the raw material for the same output.
In addition solar panels have a limited life span of about 25 years so what will happen with the vast quantities of solar panels that will no longer be effective?
Again - that is design life, not lifespan.
Creating all these so called environmentally friendly "green" solutions we are damaging the environment now and for the future and at a huge cost!
https://www.bloomberg.com/news/feat...be-recycled-so-they-re-piling-up-in-landfills
https://www.bbc.co.uk/news/business-51325101
I won't quote climate change evidence here. If you don't believe that humankind is destroying it's own habitat already, with the overwhelming evidence presented by people far more qualified to do so than me, them nothing I say will change your mind. What I will say, is that man made climate change is real whether we choose to believe it or not.
