Which tyres
4,462
As per Clive points out it's not the diameter of the rim that makes the difference its the overall diameter of the rim and tyre that's important. If teh over all tyre diameters are the same then it shouldn't cause any "wind up" problems with 4wd systems.
Reactions: JezzerB
5,489
What about different tread patterns? Would that have any effect if the vehicle is permanent AWD? Thanks.
4,462
You should review the advice the vehicle manufacture offers, but if they have supplied a space saver wheel, then they must be confident such a difference is not going to cause a problem.
5,489
Originally the vehicle came with Continental tyres however over time other brands with different treads may be fitted. This could apply to any brand of vehicle and was a general question and not to a specific brand.
3,843
Space savers are intended only for emergency use limited to 50mph and most manufacturers limit the distance used to 50 miles - so just to get you to a tyre supplier, not to complete your long journey.
Ideally, cars should have the same pattern on all four tyres but it's not an absolute.
4,462
That is why I suggested "You should review the advice the vehicle manufacture offers "
9,511
When I fitted my Sorento with Yokohamas I put the first two on the back and planned to replace the two Kuhmo on the font a month later. How I put it in 4WD for a spell and the road/ transmission noise was very noticeable. So I switched it back to 2wd immediately. That was a combination of tread depth difference and tread patterns. Needless to say two more Yokohamas went onto the front the next day.
Ive read experiences abroad where a car has a puncture non repairable and the tyre fitters have insisted on two new identical tyres to be fitted on the axle. I thought the regulations only required tyres to be the same specification nit identical.
3,843
The UNECE regulations require only that the size/type is identical across the axle - unlike the UK, some European countries have additional requirements.
Reactions: ProfJohnL
Feb 23, 2018
928
93
18,935
If it’s a spare then it should only be used for a limited distance...
Not all 4WD are the same. Haldex seem more tolerant of tread mismatch...
My XC60 with Haldex AWD does not tolerate a mis-match of tyre diameter. New rear and worn front tyres caused horrible vibrations.
