Windscreen cleaner
Since we had a new windscreen in our car paid for new wipers and rain repel, which is a coating for the windscreen any rain water it seems to run rapidly away .
I was cleaning the inside of the windscreen not the outside. I’ve used rain dispersant on the external screen with mixed results. The best one I found was Supagard. .
The problem with some dispersant is the refraction and reflection with low sun. I still fine Fast Glass and Crystal Blue applied and buffed up with kitchen roll,or similar.
For most car cleaning now I use Bilt Hamber products, for glass specifically they've recently brought out "Traceless". I guess this follows on from their Touch-less snow foam and Touch-On wash and 'wax'.
It's isopropanol-based so should evaporate and be traceless! For the caravan windows I still use Auto Glym fast glass.
For rain repellent coatings, Bilt Hamber Touch-On is sufficient for the side windows along with the paintwork, but I use Gyeon Q2 Quick View for the windscreen. Excellent performance at motorway speeds and very easy to apply every couple of months.
Internal or external windscreen? No issue cleaning external, but that fine "mist" on internal windscreen is a pain.
Like you it’s my inside screen that I was most concerned about and so far I’m pleased with the results from the E-cloths, but must admit I should do it more often which might help.
Front screen we tend to give a blast on the washers as we leave the drive first thing and always use good quality screen wash adjusted for time of year. Prestone or Sonax.
The areas not swept by the wipers are cleaned when the car is washed, or between times using Fairy Liquid and warm water.
I use Bilt Hamber Traceless for internal and external glass. [Q2 Quick View external only] but I find the regular yellow microfibre towels tend to leave behind the fibres on internal surface of my heated windscreen, so need to use lint-free towels.
I have tried recently Invisible Glass, ok on cold glass but NOT on windows when the sun is on them. Micro fiber cloths for final wipe.
