Wiring new 13 pin plug
Apr 4, 2023
5
Hinput a new 13 pin plug onto my tow car and there are 2 lots of wire [black) for light etc and grey for fridge reverse light etc).
On diagrams it shows for 13 pin wires that are different colours from pin 8 to 13 than the ones on the old grey wire from my car.
I'm certain pins 1 to 7 are correct as they are standard but the problem is everything works fine on my lights apart from when I put my side or mains lights on my right indicator stays on.
Any advice greatly appreciated as don't want too put 2 sockets on the car.
Nov 30, 2022
1,981
1,876
2,935
I have found that Bailey use a different colour coding on the caravan as they do on their wiring diagram. Which is really helpful not! Took an age to work it all out and I was only looking for the permanent 12v feed for a rear view camera.
Clearly if the right indicator stays on something isn't connected correctly, which you probably knew anyway.
5,397
Any advice greatly appreciated as don't want to put 2 sockets on the car.
Hi Mike
So it is the car you have retired not the caravan which I assume is already 13pin?
Grey wires! Very odd. Before you pulled the 7 pin “ 12N “ plug apart did you take a photo?
I suspect your problem is purely one of missiring. Best double check. But if yours are all,great and black you may need some specialist help
Apr 4, 2023
5
Cheers.its gotta be pin 8 to 13.i think from my car grey wiring yellow is for reverse and green is positive direct from battery.
My van is a sprite 2014 major.defo wrong on the wiring as it worked fine on a 7 pin plug.
Just need to know what pins the grey wire colours go to.thanks
