AGM battery Vs Solar
Oct 24, 2024
121
64
635
Well we just picked up our new (to us) 2019 Bailey Unicorn and I took along my new AGM battery to the dealership - slotted in place and was then told on the handover that AGM isn't compatible with the solar panel on the roof.
It's a damn good battery with 120 amp hours and, truth be told, if we were lucky enough to live another 10 years, we wouldn't be off grid for more than 1% of our time.
Should we for go swapping to a lead acid battery which will then be compliant with the solar panel or hold on to what we've got. The place that supplied the battery said they would swap without hesitation if anything was wrong.
As I know next to nothing about this, I once again seek your wisdom.
4,230
1,951
At the most all that will be needed if the existing solar controller has no provision to cope with an AGM battery, is replace it with one that has.
Suspect there is someone seeking to extract money from you, by giving at best half a story.
What solar controller is fitted?
Reactions: Jcloughie
9,668
I’m very surprised at the dealers comments. Searching the internet shows a number of suppliers for panels and AGM batteries. Could it be a mismatch on the controller?
Reactions: CrewOVtwo
Oct 24, 2024
121
64
635
Yes, now you both mention it, it's the controller that will ? 'burn out' I think he said - but I don't want to cast aspersions on the dealer as they were excellent, and any omission of facts is due to my lack of knowledge.
I'll ring them again tomorrow to clarify things.
I know in the relatively near future we are hoping to spend extended periods in sunny climates so it would seem daft to not make use of solar power.
Aug 12, 2023
685
320
2,135
I very much doubt controller doesn't support AGM as that has been default battery for years, it's only recently that solar controllers have started supporting LiFeP04. NB modern controllers even £10 PWMs will support a range of battery types.
Ask dealer for controller model number and manual. Any new caravan will come with folder full of manuals for all devices/appliances in caravans.
4,230
1,951
Again highly an unlikely outcome, the issue is way more that the battery is not going to be charged in an optimum way, and that possibly leading to it having a shorter working life than it might.
I would not be having any further discussions with the individual spinning you their line as from what is reported I simply don't "buy" that they know what they are talking about.
Just identify what actual solar controller you have fitted and tell us, then members here with knowledge in this field can look up its specification and give you a better, fact based guide to what, if indeed anything, is the right course of action.
5,505
If the solar panel controller is a Truma it is quite simple to switch it to AGM. We have an AGM battery in our caravan.
Oct 19, 2023
639
510
2,135
Hope this helps.
Looks like a Truma SDC 10. Link to operating manual below which says that it has a setting for AGM batteries.
Reactions: JTQ and Buckman
Oct 24, 2024
121
64
635
I've got the manual with the van so will search through it later this evening and report back.
Thanks so much for your continued help.
4,230
1,951
Yes, beat me to posting, having also just found the manual for what seems to be the OP's unit.
Shame the trade for whatever reason are giving out such misinformation.
Reactions: Beardy and Buckman
Oct 24, 2024
121
64
635
Thank you gents. Have found the manual and it told me how to change the settings to AGM.
The solar charger is a SDC 10/20 and using the 'SET' button I was able to access a scrolling menu of numbers to the '2' which corresponds with AGM.
I owe you a beer or two.
5,505
Now to rub the sales person's nose in it! LOL! :ROFLMAO:
5,505
IMO though, it is way better to keep away from alienating your dealer so early in the "journey" with them, but quietly knowing you need to doubly check their advise.
However I would mention it to them in passing. Seldom is it the consumer that alienates the dealer, it seems to be the other way around once they have your hard earned dosh!
4,230
1,951
We each have our own chemistry, believe me though, sellers are as easily able to form opinions of customers as the other way. Been involved in both camps over the years.
