Bailey Pageant 2006 water pipe fittings?
Nov 25, 2025
Hello, I have an older pageant but am struggling with the water pipes. I need to cut one and add a T-piece in but everything I find online is showing the 12mm John guest fittings. Mine seem to be the older style where the pipe pushes over the fitting and uses a jubilee clip to secure it.
Hoping someone knows what these fittings are called or where I can order some from? Not sure if I can get a connector to convert to John guest? Only need a tiny T-piece to come off the hot water pipe. Thanks a lot
Oct 8, 2006
2,108
764
Pageant is a range of vans. It would help to know which Pageant model and which series. For instance we used to have a Pageant Majestic Series 5.
Oct 8, 2006
2,108
764
it’s a Bailey pageant series 5, thanks. Sorry quite new to caravan’s
Sorry, but you still don't get it. Pageant is a series of vans all of which have a name. For example Bailey to a range called Unicorn, but each of those has a name within the Unicorn series, such as Madrid, Seville, Valencia. Your Pageant will also have a sub-name - ours was Majestic so was known as a Bailey Pageant Majestic Series 5.
So what Pageant model is yours? It should be on the side panel towards the rear and have the name of a French area such as Provence, Bordeaux, etc.
671
536
1,135
@Tom199922 have you measured the ID of the hoses ? the link birdman sent is good , the adapters come in a range of sizes so you need to check , the last Bailey I did with these type of hoses , the ID was 10mm.
3,927
All models of Pageant for the same model year will use the same fittings - don't get hung up on demanding the model name from the OP.
2,695
Hi Tom199922 welcome to the forum you should get all the help and advice that you need, and how to complete the job .
