Battery Problems!! Help
Feb 3, 2016
After fitting a new vehicle battery, I found that the domestic electrics will now only work with the ignition switched on, before this the domestic electrics would automatically switch off as soon as the ignition was switched on.
So now the domestic electrics is only running from the vehicle battery and not the leisure battery? Compass Avantgarde 100 Peugeot chassis.
What have I done wrong??
gjh
Jul 28, 2011
618
If your van is like our former 2004 Autoquest 100 you will have a switch on the control panel marked AUX and VEH. AUX is the leisure battery and VEH is the starter battery. Have you inadvertently switched from AUX to VEH?
If that is not the case, has a Battery Manager (or similar) box been fitted and somehow the wiring has been wrongly reconnected to the new battery (bit clutching at straws that one)?
If neither I would have the wiring checked by an electrician.
Graham
