- Jun 16, 2020
- 5,821
- 2,747
- 17,935
As a matter of interest , just to confuse this old dog more, there’s nothing in the handbook explaining the brake lights stay on. I hope it hasn’t got a hidden MCAS🤪🤪🤪🤪
Mast cell activation syndrome ?
Or Machinery Control and Surveilllance.
By coincidence police cars which have been alongside at lights all had their brake lights onI thought that the driver applying the hazard lights was the correct procedure. 😀
But I agree with Dusty that it’s still annoying when in traffic to sit behind a row of high intensity brake lights, especially when wet.
Still doing quite a bit of nighttime town driving brakes lights illuminated are the majority and I don’t notice them going off as handbrakes are applied.When the question is worded as “can you confirm you were stationary and your brake lights were on” I think I’d sooner say yes because I’d prefer not to muddy the water and risk being part at fault, with modern cars flagging warning lights on the dash if a bulb isn’t working you could confidently say they must have been illuminated or I’d have had a warning light, I understand what people mean about the glare but it’s often for a short time and if it’s a long delay lots of people put it in to neutral and apply handbrake, the ones with foot on the pedal I’d put at the minority, but then again the majority of my driving is daytime so I could be wrong, there are lots of worse bad driving habits, my biggest bug is people failing to indicate, now that’s a lot more common I think. Doesn’t matter how good your own driving is there’s plenty of idiots who behave like they’ve never passed a test.
BP
Even more reason to assume the lack of a brake light means a vehicle could be slowing or stationary.The "Highway Code " is just that that and not the law, you do not have to put a handbrake on, I learned to slow down using the gears on the Car/ motorbike, not the brakes, as i believe is normal now,.
The Highway code tells us when we are stationary for example at a junction, we should apply the hand brake. That does not display the brake lights.
On two police driving courses ( not speed awareness) it was pointed out that much of the Highway Code is embodied one way or another in legislation. Where it is not non adherence could count against you if it came to a court case.The "Highway Code " is just that that and not the law, you do not have to put a handbrake on, I learned to slow down using the gears on the Car/ motorbike, not the brakes, as i believe is normal now,.
That is the correct way to drive as indicates you are observing the road ahead and taking into account all changes in your surrounds. It is the responsibility of the driver behind you to be maintaining a safe distance and also to be observant.The "Highway Code " is just that that and not the law, you do not have to put a handbrake on, I learned to slow down using the gears on the Car/ motorbike, not the brakes, as i believe is normal now,.
My last police driving course was in the mid 1980s and slowing down on the brakes was taught back then. But in town I was continually told to drop down a gear or two as controlling speed is easier by use of the throttle. Similarly on the open road. Where I would normally be in 5th the instructor would be in 4th. But always proper braking was done on the brakes not gears.That is the correct way to drive as indicates you are observing the road ahead and taking into account all changes in your surrounds. It is the responsibility of the driver behind you to be maintaining a safe distance and also to be observant.
Emissions requirements have changed things a lot since the mid 1980's. In order to reduce emissions it is nowadays generally recommended to change up a gear as soon as possible.
Technical changes that were previously unheard of have also appeared lately. I mean things like white daylight running lights that turn into amber indicator lights when making a turning or sequential indicators that VW/Audi and perhaps other manufacturers, too, are now fitting.
That is what I have done for years. And with the Auto Hold system its simple.Technology and Highway Code appear to have parted company. I suspect EU regs have something to do with German car makers approach to safety .
Back in 2013 my copy of the HC says:-
“In stationary queues of traffic, drivers should apply the parking brake and, once the following traffic has stopped, take their foot off the footbrake to deactivate the vehicle brake lights. This will minimise glare to road users behind until the traffic moves again.
Law RVLR reg 27”.
Millions of drivers totally ignore this code but maybe today it is not enforceable .
On the assumption all vehicles sold in the U.K. are designed to the very strict vehicle design and construction regulations I have to assume VW have got it right and our dazzling prejudices are no longer valid😢😢
