What vehicle? As my sportage does not have that function.Mine is in the vehicle settings menu on the touchscreen
Lots of changes are possible on VWs as the software is global, so some things can be coded out by selecting a country option where the feature isn't mandatory.What vehicle? As my sportage does not have that function.
if it in a Ford Kuga i be looking in my menu settings 👍Mine is in the vehicle settings menu on the touchscreen
how do you do it 🤔
That is exactly how the Ghost immobiliser works. You need to input a sequence of presses to access the vehicle. I think yours has an after market fitting as no such thing in either of our cars? It is the damage they cause trying to access the car before they realise it will not start that is a concern as the damage could run into the thousands if they have damaged wiring etc.It is usually a sequence of presses of the fob and the touch panel on the front door handles, or there is a button to press before you exit the vehicle, or its on the infotainment system. Whichever you do it is straight forward and simple. I won't say the sequence in our car but it works!
Many dealers will tell you that the key puts out a continuous signal or that the fob goes to sleep neither of which are true. If you go to open the car by touch (keyless) and look at the fob at the same time you will see a LED on the fob flash. That LED flashes once every time the fob transmits, and it doesn't flash when the keyless operation is disabled.
Not after-market - standard factory fitted item. I didn't state the make and model of our car so how can you say it is not on other vehicles?That is exactly how the Ghost immobiliser works. You need to input a sequence of presses to access the vehicle. I think yours has an after market fitting as no such thing in either of our cars? It is the damage they cause trying to access the car before they realise it will not start that is a concern as the damage could run into the thousands if they have damaged wiring etc.
Someone on another forum suggested the Pedlock which looks very robust and is a very visible deterrent. Having has two cars stolen in the past albeit not in the UK, we do not want another car stolen. Link to Pedlock. https://pedlocksecurity.co.uk/product/pedlock-universal/
Not sure where I said that although I did say it was not on either of our vehicles. If it is a standard fit on your car, perhaps that brand suffers from a high percentage of theft hence the additional security as standard? Ours are Toyota cars.Not after-market - standard factory fitted item. I didn't state the make and model of our car so how can you say it is not on other vehicles?
We have the tracker fitted in our Lexus and it is not a Toyota tracker although they fitted it. It si the basic aTracker Retrieve from Tracker. Tracker's home office is in Durban South Africa and they have far more experience than any tracking experience than any UK tracker company. Our son who drives a Landcruiser had to have two trackers fitted to get insurance and he lives in the bush! LOL! 🤣Unfortunately if the thief wants the vehicle. Then its going.
They dont need the keys any more. The AA and Rac etc have gadgets to over ride the alarms, open the vehicle and start the cars through the canbus smart system.
And the thiefs have got hold of these gadgets now.
Im even aware of a toyota. Antitamper canbus device fitted.
Ghost imobiliser fitted
Steering wheel bar fitted. ( Got cut off with grinder )
And it was pinched.
They only got it back as it was fitted with toyotas own tracker. which only gets activated once vehicle is reported missing. So thiefs can scan car once they pinch it. They think theres no tracker. as it wont show up as its not actively transmitting. So they thought they were safe.
Then once its reported missing. Tracker gets activated 1 hour later and its location is immediately sent to nearest police patrol.
The Toyota RAV4, which shares a lot with the Lexus NX, is the 5th most stolen car in the UK https://www.bournemouthecho.co.uk/news/25221545.stolen-car-models-revealed-uk-past-year/Not sure where I said that although I did say it was not on either of our vehicles. If it is a standard fit on your car, perhaps that brand suffers from a high percentage of theft hence the additional security as standard? Ours are Toyota cars.
Many reports say it is because they are easy to steal! 🤷The Toyota RAV4, which shares a lot with the Lexus NX, is the 5th most stolen car in the UK https://www.bournemouthecho.co.uk/news/25221545.stolen-car-models-revealed-uk-past-year/
I will look them up, never heard of them before, thanks.I have put the special, and expensive CR2032 batteries that go to sleep in our key fobs, so if a key is not moving after 3 minutes it goes to sleep and so then there are no signals for the thieves to clone.
Seems to me to significantly reduce times we can be targeted by that particular technique, particularly as now I put the "in use" key down rather than leave it in my pocket. Other lives in a metal safe, secure in three ways, Faraday cage , asleep, and physically secure.
Ford Ranger, not really surprised a nice new one has an unwelcomed appeal.
Like Birdman, we have 3 front cameras and 1 rear. 2 are tracking cameras plus a doorbell. All Tapo, which works for me.Unfortunately the camera would over look a public walk way as we do not have a drive. A bit wary of infringing any Data Protection Acts.. However an outdoor light that coming on may act as a deterrent. The car is about 5m from the home and parked on the street.
It does not mention the age of the RAV4 that is being stolen as there was an issue with earlier models. The Lexus and RAV4 are very similar and since 2022 thieves can no longer access the CAN Bus as per earlier models. It also refers to being stolen using key relay tactics so in essence, the owner is at fault.The Toyota RAV4, which shares a lot with the Lexus NX, is the 5th most stolen car in the UK https://www.bournemouthecho.co.uk/news/25221545.stolen-car-models-revealed-uk-past-year/
I had a Co car, a Citroen Xantia estate reg P204SGH so a 1996 model and that had a numeric keypad that requied a four or five digit code - which you could change at will - before it would start. 29 years ago and they've still got nothing much better!I would have thought there would be an after market product installed in the start system that requires a PIN to be spoken to it or even keyed in, little doubt it could be hard wired out but that would add a bit more hassle to the thief's task? Mobile phone app enabled?
I have to concede I do like the innate simplicity of the fob batteries that go to sleep, coupled with a practice of leaving the fob static when not required, just I don't like the massive premium price the vender asks, at present.
A work round any Patent protection could be that functionality being integrated into the fob itself?
We had two Passat estates that had and they had this system, albeit much easier. If set for driver's door only, one press on the fob unlocked the driver's door, a second press opened the others. All doors were deadlocked when locked.It can be set to unlock all doors or just the drivers door. If set to drivers door only, then driver unlocks others when inside,
That's good that it's a "drop in the ocean" if your car gets stolen.There are approximately 34 million vehicles on the UK roads so when about 70000 are stolen it is a drop in the ocean. Not sure what percentage that is, but it then puts the report by the Bournemouth Echo in to perspective.
Linked to that is that the 34 million cars are all paying the inflated car insurance so that is a lot of money that insurers are sitting on each year. Having had two cars stolen, it is not pleasant to be that drop in the ocean especially when there is no such thing as public transport available!That's good that it's a "drop in the ocean" if your car gets stolen.
We have one front camera but next door neighbour her front camera is wired in and often keeps and I on hers daughter touring caravan and our two cars but we have a outside light on the garage and bungalow and it got motion detection .so far okayLike Birdman, we have 3 front cameras and 1 rear. 2 are tracking cameras plus a doorbell. All Tapo, which works for me.
How a camera is directed seems to be open to interpretation. Clearly they should not be looking over other peoples property. However mine can see over neighbours front gardens. As they provide security for them, none are bothered.
I do not have the alarm turned on. That would mean very many false alarms every day. Set off by passers by, cats and foxes.
A few weeks ago a lady went missing and there was a police search. They examined my films and were complimentary regarding the quality, and no complaints regarding the direction.
