Cleaning caravan roof
Feb 13, 2024
1,353
856
1,435
Started cleaning the roof of my van. I just used a spot of bleach mixed with hot water in a spray bottle. Seems to be working OK. What do you guys use?
Jan 19, 2002
1,706
547
This year used an Aldi special caravan shampoo with an extending brush - and very pleased with the results. Usually used Mer or Care-avan or a quality car shampoo. Not sure I would trust even dilute bleach not to affect plastics or acrylics like roof lights or windows?
9,158
I always used Fenwicks caravan ckeaner. In spring I would be cleaning off the Fenwick overwintering coating that was applied in late autumn. That traps muck and algae and the caravan cleaner fetches it off very well. Then a quick spray with Fenwicks Bobby Dazzler. I have no affiliation to Fenwicks. It’s just that I found their stuff worked for me. Periodically Autoglym Resin Polish would be applied once a year.
Reactions: Deejuk
Dec 27, 2022
592
428
2,135
I use Greased Lightning and lots of Micro Fibre cloths works well for the whole van. You need to change the application cloth on a regular basis. Being waterless it means I can clean the van anywhere, even on site 😱
For getting rid of green there is nothing better than Patio Magic, just spray on and walk away it does it all for you.
JRT
May 5, 2024
271
180
235
Fenwicks caravan cleaner. Mixed a little stronger for the roof, which only gets done twice a year at the most.
The rest of the 'van gets done a couple times more.
5,396
Fenwicks Caravan cleaner mixed with warm water, green nylon sponge thing, plenty of towels and Fenwicks Black Streak remover for the really stubborn bits. And plenty of elbow grease. Next day all finished off with Autoglym Super Resin Polish.
Reactions: toad a caravan
5,297
When can we bring ours around for you to clean the roof? :ROFLMAO: :ROFLMAO: :ROFLMAO:
2,592
We used Fenwicks caravan cleaner mixed with warm water and a micro-fibre cloths and then spray some Fenwicks Bobby dazzler and it would leave nice shine.
640
Used Gunk traffic film remover this year, did a good job, for the black spots I used gentle scourer pad
Sep 2, 2023
122
89
1,635
As a slight aside but relevent here. Has anyone devised a tool / method of cleaning off all the gunk that accumulates in the narrow gap under the solar panel?
Oct 8, 2006
2,046
722
Muc-off. And if you put a small amount in your washer bottle you will never have /grease/smear problems.
It is water soluble and biodegradable.
