Feb 4, 2026
10
I have a 2020 Elddis Affinity 520 which has developed a leak from the large skylight which runs most of the length of the lounge. We are expecting the dealer to sort it out but this is the third leak in five years. I would like to remove the large plastic surround to take a closer look to identify where the ingress is taking place but can’t see any obvious fixing points. Does anyone know how to remove the surround?
Jun 6, 2006
1,037
254
In all honesty I don’t know, but it could be it come off in a similar manner as most windows, as in undo window struts, open window up as far as it goes and the two hooks (window bar and hinge bar) come undone.
Reactions: Goldhillman
May 18, 2006
596
20
18,885
Our 2017 Buccaneer leaked from the large skylight last year and it was replaced under warranty. If your van has full service history then the dealer should be able to submit a warranty claim. Good luck.:)
Nov 30, 2022
2,016
1,916
If you are still under warranty just proceed with caution with any DIY investing. You may well be totally competent for the job; but any excuse to declare a warranty invalid because of “user involvement” can be conjured.
Very sage advice!
Its a sklight not a window, totally different things
Jun 6, 2006
1,037
254
I realise it’s a skylight, they are not your standard 400x400 (that are normally fitted) but a long thin skylight, hence my post where they could come out in the same manner 🤔
Edit….
If you read what I said above I clearly said in a similar manner to most windows, so I obviously knew it wasn’t a window 🤔
654
524
1,135
Martin-E He was asking about the plastic surrounding the skylight (see photo) not the window itself .These either have secret screws covered with caps or they clip on to a frame underneath which is screwed to the roof , some have detachable corners which when pulled off revealing the screws . Having said all that , the advice the other members have given stands , if under warranty don't mess!
Feb 4, 2026
10
I am taking your advice. Going in to dealer on Saturday for service and replacement of front (leaking) skylight so it will be investigated then.
Reactions: toad a caravan
2,668
I am taking your advice. Going in to dealer on Saturday for service and replacement of front (leaking) skylight so it will be investigated then.,
But i hope the dealer corrects your leak on your skylight but keep us updated .
1,494
661
2,435
I've heard rumours that the area (around certain Elddis models)hadn't had the realise agent removed properly on the roof where the skylight is positioned, therefore the sealant wasn't adhering.
