Leisure battery help!
Another step along the learning curve this morning…All ready to go and turned on the motor mover to hitch up. Nothing! Leisure battery is completely drained. We have now connected to the mains at the house and wondering if we should be charging between trips? Also, how long before we can head off? Finally, will the battery charge as we drive (it’s a 3 hour drive). Any help/advice greatly appreciated!!
For a start how do you know the leisure battery is flat? If the mover won't work it does not necessarily mean you have a flat battery - it could be a handset fault. Have you used a meter to check the battery terminal voltage? Does the battery have a small window on the top which should be showing green?
If your leisure battery is flat then (a) you may need to replace it if its terminal voltage is much below about 9V and (b) if it is flat then something must have been drawing current to drain it. Did you switch the caravan power off last time you parked it up? For that matter is your towing vehicle wired to charge the battery when you are travelling?
It would be helpful to know the make/model/year of your caravan and details of your towing vehicle and the electrical connection between them (i.e. 2x 7pin or1x 13pin.) Indeed, has there been evidence that the battery has worked with you car in the past or is this a new event?
Thanks for your reply. It's a Swift Challenger 560 and we're towing with a VW Tiguan. When we connected to the mains at the house, I left it for 15 minutes and then tried the control panel. It said 'Leisure Battery' critically low and beeped loudly. Now when I have turned on the control panel, it lights up but only the awning light button is responding.
Not much help to you at the moment but I can recomend an Ancel BM200 if your caravan is parked at home. It's so easy to open the app and check the state of your battery.
Edited as the I can't get the link to work propperly. Google Ancel BM200 - they can be bought from Amazon, eBay, AliExpress etc.
Traditionally you might expect the car to charge the caravan battery whilst towing, but many modern cars now have "Smart Alternators" which do not constantly produce power so it may be uncertain if your car is charging the caravan battery. You might ask your car dealer if yours has a smart alternator, or if it can be programmed to keep the trailer battery wiring active.
However regardless of whether the alternator is charging the caravan, a 3 hour trip may not be enough to fully replenish the battery, so it is potentially a good idea to at least periodically charge the battery whilst the caravan is in storage.
The other thing to do,is to make it a strict routine to check that all appliance's have been turned off when you put the caravan into storage. Some caravanners discover there can be parasitic 12V devices (tv aerial amplifier is a common one) However you may need to leave your alarm system connected if that is a criteria stipulated by your insurance. Check with your caravan dealer about how it is powered.
After my last outing I discovered that my fridge draws power from the leisure battery if it isn't turned off on the fridge selector switch (even though the caravan main panel is turned off). I noticed that the battery was getting low even though I have a small solar panel to maintain it. It was dark when I went to check and as soon as I opened the caravan door I saw that the fridge light was on (I prop the fridge door open when it isnt in use).
Depending on how low the leisure battery has gone, it may be discharged past the point of no return. ☹️
When you are not using the Caravan make sure that the Black button on the Sargent box under the offside front seat is in the Off position ( ie up) to stop all draw on your leisure battery. Your solar panel ( if you have one) will still charge the leisure battery and the alarm will still work.
Charging your battery between trips depends on how long between trips.
I take my battery out if I know it's going to be over 4 weeks, before going out again, on many caravan there are " hidden " power drains for the battery. ie, the alarm , the fridge control panel, the TV booster, the radio in the van etc.
If you have a solar panel then this will charge your battery.
I do tend to disconnect the battery every time I leave the van in storage as the alarm has its own power supply.
Depending on how "dead" your battery is you might get away with just recharging it, I managed to resuscitate my battery once, it was below 9 volts,
I have a Nexpeak battery charger which has a recovery mode.
Woodentop asked a good question, about the battery actually being flat, as I had the very problem he pointed out, the battery in the hand controller was flat.
The source of your problem could that the 12v was not switched off. This will drain the battery fairly quickly.
@Didi :- Profs post is spot on , three hours is definitely not enough to charge a flat battery and it my be terminal - lead acid batteries don't like being left flat. When charging from the internal charger/PSU it will put a lot of strain on it and the 20A battery fuse, they may get warm including the fuse holder so monitor it . A separate mains powered modern 'smart' charger may be a better option to recover the battery if at all possible.There are several on the market and I'm sure the members have recommendations.
My original leisure battery [6 years old] did not survive after being left unpowered on a seasonal pitch and would not hold charge. It would turn on the motor mover but died after the motors started turning. Sadly my CTEK battery charger used to nurse the car's battery through lock-down did not revive it, so OP's is probably toast.
Local dealer tested it and confirmed it's was dead, and said it was undersized for my caravan/mover. Annoying as they supplied it when new. Since replacing the battery, it survived 2 full seasons with no issue, but I always turned off the caravan electrics at the power board under the seat before leaving.
If the OP's Tig is not too old and has an Infotainment screen it would be a good idea to make sure the system controller (computer) has been updated to tell it you are towing. All that is needed is to connect up the caravan to the Tig and start the engine, then put it into reverse for a second or two then back into neutral. The screen display should change to show any objects detected by the ultrasonics. If the computer has been notified the you will get a pictorial diagram of the Tig AND it should show the A-frame of your van. If it does not show the A-frame then either the computer hasn't been updated OR the power connections on the 13pin socket are not wired. The pins are 9 (with 13) for the unswitched supply and 10 with 11 for the fridge and battery charging. Although I believe VAG towing electrical kits are now fitted with the extra pins for 9 10, 11, and 13, on earlier models they were not. The pin numbering/layout is moulded onto the inside of the socket cap, or of course it is easily found on line. If the proper VAG kit has been used there will be a fairly thick multi-core cable under the carpet down the nearside to the fuse box behind the glovebox.
Contrary to much popular belief, towing a caravan does NOT cancel start/stop operation - I know from our previous Passat 2LTDI 150GT estate and our current Skoda Karoq 2L TDi Sportline and believe me the first time it happens it comes as a bit of an unexpected shock! Just override the start/stop facility.
WoodenTop, please enlighten me, the Acronym Tig, what does that mean.
Thanks in advance.
Just got it Tiguan. Doooh.
@IanB1485
The only problem with most smart chargers is that they won’t start to charge a flat battery if the voltage is under its range, the range varies from 8-11v depending on smart charger.
You can trick them by piggy backing another leisure battery to kick the charger into life, then disconnect the second battery once the charger has kicked, but leaving the original battery attached to the charger during disconnection
Our caravan battery, a 9 year old Yuasa AGM 90ah is still going strong and currently being used at home It site sin the shed during the summer and is brought into the house during the winter in case of a power cut. It has been flatten twice down to 6v early in its life.
If your battery looks to have died and you are capable of doing it, there is a way that will usually 'bring it back'.
Put a 21W flasher bulb in series with the 12V+ cable and connect a 12V (or so) power supply to the cable end. (If your van uses a constant voltage supply such as Bailey do, that will suffice to provide the power.) When first switched on the bulb will light up brightly but over time will gradually dim until it no longer glows. This can take a matter of minutes to over an hour. Leave it connected for a couple of hours, then disconnect and after maybe 5 minutes check the battery voltage. If the voltage is steady and above about 10.5V take the bulb out of circuit and reconnect the battery in your caravan and switch the caravan mains supply on (or use and external smart charger if you have one.)
I have done this twice and both times the battery came back and continued working for at least a year afterwards.
For those of a certain age (like what I am) you will remember from Physics at school that the bulb method was how many battery charging systems worked, especially those huge glass lead acid cells found in places like telephone exchanges.
Our caravan battery, a 9 year old Yuasa AGM 90ah is still going strong...
Original "starter kit" battery supplied by the dealer was Banner branded and lasted 5 years. Purchased a higher capacity Yuasa battery, not AGM, from same [now defunct] dealer as I was already at their site; hopefully will be as long-lived and reliable as yours.
The three main battery brands these days these days AFAICT are Yuasa, Bosch, and Varta. Halfords leisure batteries are rebranded Yuasa. We have a Varta 90Ah and it is still going strong from when we got it with our previous van early in 2018. And yes, we have a mover.
As a (now) longish retired radcomms engineer I can report that when fixed equipment - uch as a radio base station or certain emergency service kit had backup supplies - I would more likely than not find Yuasa batteries were used.
I think it's highly unlikely Halfords manufacture their own batteries, they will almost certainly have a contract with some other manufacturer. However just becasue someone may have seen some produced by a well known manufacturer for Halfords on one occasion, it does not mean the same supplier will be used for all batches. There is a report from about 2009 that claims Varta manufactured some for Halfords.
Even if a particular manufacture has been identified as the supplier, It's illogical to assume the Halford batteries will have the same exact features as the manufacturers own retail products. Halfords will have negotiated a contract to meet a price, and the manufacturer will will want to retain some technical advantage to justify their own higher retail prices. There could be internal differences that are not obvious to the casual observer.
Reactions: JTQ
I may have posted this before but a big giveaway to the quality of LA/AGM batteries is the weight. Lead is relatively expensive so one means of cost cutting is reducing the amount used by making them with thinner internal plates. Thinner plates are more prone to buckling and shorting out, especially when over discharged, leading to total failure. If you think that a particular battery is a straight forward 'rebadge' of a battery manufactured by someone else, compare the weight of their equivilent (it's normally given in the specification).
My goodness, thank you so much, everybody. This is such helpful information. A lot of learning to do. We have found a very local caravan repair man who is going to check on the battery for us and see if there is anything untoward. Again, thanks for taking the time to share your knowledge - much appreciated!!
