Motor Mover Cable Rating
Aug 6, 2010
6
Hi To All
A newbie here I am afraid
I have a Carver / Truma Single Axle Caravan Mover. Possibly now Truma Original Motor Mover
The Control box is a Model AR2-1 Part Number M606929
Can anybody tell me the cable rating required from the control box to the motor
Failing the exact rating a normal expected will do great
Many thanks
936
You need 8mm multicore cable and both sets of cables MUST be of equal length.(the extra length from the nearest motor being coiled up inside the van)
If you only wire to suit the position of each motor, as one is further away from the control box than the other, you will get a mover which will not work as it should due to voltage drop and more power being available at the nearest motor.
Aug 6, 2010
6
Hi Damian
Many thanks for your reply
I have trawled for so long looking for this I was beginning to think it was a national secret. The cable length makes perfect sense also
Once again Many Thanks
