- Mar 14, 2005
- 19,146
- 4,342
- 50,935
Dustydog said:....
Hi Prof.
It's a very sad day when a newbie on here is told most commercial measures are rubbish. I fully appreciate your point which is valid but you didn't acknowledge my earlier comment that I and indeed others on here have measured our Reich readings against your bathroom scale method. The difference was negligible.
I think it is very unfair to dimiss the Reich as "not fit for purpose"
Maybe it's time for PCv to research the various nose weight measurement methods and publish the result . There's nothing stopping them seeking counsel from Milenco, Reich etc
I encourage new caravanner's to take the technicalities of towing seriously, that does not mean they have to fully understand the underlying principles, but more importantly to know how to mange them sensibly. Nose load we all acknowledge is important from a safety angle, and most would also acknowledge the limits of both car and trailer should be observed, so having the right means of doing that must be important.
If someone makes the effort to purchase a nose weight gauge, they should expect it to be capable of doing the job they are purchasing it for. That should include a reasonable degree of accuracy in displaying the applied load, and that it will facilitate the correct measurement process, Quoting Milenco's usage of BS7961:2004 it calls for an accuracy of +/-2kg especially where there is a legal requirement (regardless of whether there have been prosecutions or not). Any product that fails to do what it should be doing is by definition not fit for purpose.
Of the commercial products available the Reich model is probably the most reliable, as it uses load cell technology. Load cells are a robust technology extensively used in industrial weighing noted for reliability and good repeatable accuracy. so this should give good consistency of measurement.
Another important aspect of load cells is they barely deflect under within range loads. This answers the issue of changing length under load another of the fundamental short coming of coiled spring technologies.
So two up for the Reich, but the third issue is still a significant source of error, and that is the fact it raises the hitch by the height of the device which from observations seems to be about 75mm, which is bigger than the EU permitted range of loaded tow ball heights!
Reich clearly appreciate the force measured is not the the same as the nose load produced directly at the tow ball, because they tell us the device compensates for the height error. This means the variations is enough for them to consider it necessary to make a compensation, and they found it necessary to produce dedicated single and twin axle models. However they don't tell us how the compensation is established or how it is introduced into the device, the absence of any user programmable variables suggests the compensation will most likely be a fixed additional figure of a number of kg.
If the compensation is a fixed parameter, then it can't accurately take into account all the factors that affect the variance in nose load with height. We do know that twin axles can have a very aggressive change in nose load with height, and the direction of change is not certain with out checking the individual caravan concerned.
It is encouraging to see the Reich has produced a limited number of empirical results that have close agreement with the more technically correct bathroom scale on a step method, but that is not enough evidence to confirm a whole hearted approval for all car and caravan combinations, as it fails the at height requirement,
The Reich improves on two out of three point of contention over coiled spring gauges. Whether its inherent inaccuracies are acceptable in law is not known.
I totally agree, the magazines should be supporting best practice, and I also believe we should be doing the same on forums and at the same time discouraging poor and bad practice,
I think PC should review the efficacy of the range of retail gauges and their ability to comply with the EU measurement of nose weight. but will we see a true scientific approach that reports warts and all?
If a jobs is worth doing, its worth doing properly. and that applies to measuring nose load and magazines reviews of consumer products.
