John,
In theory your logic sounds good, but..............it,s not quite true, it is possible to be blown over! However, it would depend on various variables, such as;
1. The surface area of the side of the caravan the wind is hitting.
2. The angle of attack of the wind (what angle the wind actually hits the caravan).
3. The wind strength.
Get all 3 right(or should that be wrong?)then over she goes, irrespective of the corner steadies being down, they would just bend if the pressure induced weight exceeded their design capacity.
Way back in 1900 & frozen to death, we were staying at Peran Sands in cornwall, in our then Robin 4 berth, sited at the top of the cliff, in the teath of a gale, the caravan was rocking so much, that in the middle of the night, during the gale, I hitched up the tow car, lifted the steadies just enough to clear the ground and then turned the whole unit around to face into the wind, wound down the steadies, left the tow car attached.
My reasoning was to present as small as possible area to the wind & also if it was designed to be towed at 60mph then there should also be a safety margin built in, say 25% so it should remain safe up to about 75mph. Result a safe, but sleepless, night, even sheltered a couple who's tent had blown down.
Ever since then, if sited in an exposed place, I always try to put the front of the van into where the prevailing winds are coming from (just look at the way the trees are bent over)& be prepared, if necessary, to take down the awning & to reposition the van.
Hope I haven't scared you too much!
GeorgeB
