Quest Leisure Caravan /Motorhome Double Steel Step with Handrail anti-slip rubber mats
2,692
We brought the item above thought these would be okay but still having doubts i am going to fall I fairly tall 6ft 5ins
Can you suggest some that are sturdy and good weight for rough ground
Sep 23, 2023
1,508
666
2,935
BB...My cousin had the same style of steps for his caravan,(seasonally sited ) I have used it several times in the past and along with my cousin who's partly disabled haven't had any problems,I to am also 6'5""
Reactions: Beachball
9,658
You can get two hand rail caravan steps. Alternatively you could have a “folding” handrail fitted to the caravan on the other side to your step handrail.
2,692
Hi clive that a good idea having a folding handrail to the caravan thanks for your input 🙏
4,838
We bought one of those steps with the handle , but the are very low and tend to sink into rough ground, at least you can move the hand hold to either side depending on your door.
Why not get a paving slab to put in front of the entry door then it is level, and raises the step up by 1 1/2 inches.
9,658
There is also something like this
WARNING: Lie down and take sedation before reading the price
Be easier for a seasonal site to take the wheels off of the caravan, or drop them into a gouged out area.
Reactions: Mel
Feb 13, 2024
1,585
1,019
2,935
Another 23kg to add to your pay load, but it would certainly lighten your wallet 😀
5,580
Send them back BB before you break your neck. The tiny feet will sink and as you "lean" on the left rail I can see a lot more weight put on the left feet and over you go.
Plus one for Clive's suggestion . Rail(s) on caravan.
Reactions: Mel and Beachball
5,505
Those are terrible on soft ground as the feet tend to dig in one side or the other. Found that out the hard way. You need one with the bar around the feet as that stops it sinking into the ground.
Feb 13, 2024
1,585
1,019
2,935
As I posted, a good wood butcher could make a ramp, steps to your specification and sink into the ground,
2,692
Already order a handrail for the caravan (y)
Reactions: Mel and Dustydog
2,692
Might ask the site owner and see if they put me a paving slab down at the door entrance thanks 🙏
5,580
Plus 1 with Hutch.
BB definitely not one for the caravan shower walls🙀
But do ask the caravan manufacturer for their advice
5,505
Might buy them for our shower in caravan and home thanks 🙏
I certainly would not use it in a caravan as you will pull the wall away. Plus the caravan wall is probably porous. We have one at home and before placing it on a tiled wall, make sure that the surface is super clean.
