Rear view camera installation - Bailey Unicorn
Apr 8, 2019
47
27
10,535
I'm interested in how people have installed a rear view camera to the back of their caravan (Bailey Unicorn, ideally, Madrid). where they got the 12v feed from, how/where the wires went and how the camera was secured to the back. interested in both wireless and wired set-ups (how / where the wires went from caravan to car in wired set-ups)
I'm not interested in the battery-type camera as I need it to connect to my car system, and they're not compatible.
Note, I installed a wireless camera on my previous caravan and got the 12v from the rear lights, feeding the wire through the back of the high level brake light (camera was at the top of the 'van) down through the paneling to the rear lights. can't do that with this van :(bessie rear camera.jpg
Nov 30, 2022
1,927
1,796
2,935
I have fitted a wireless system to my Phoenix. Power (and return) taken from the fuse block under the front bench corner. Then down through the floor, zip tied to the cables running along the floor, back up through the floor into the cupboards/wardrobe at tue rear and then out through the rear panel at the top. Correct sized hole saw used (18.5mm) along with grommet supplied with the camera has kept the water out for 6 years. Camera mounting bracket Sikaflexed onto the rear panel near the top, excellent view back down the road over the top of following traffic..
Works perfectly as the camera is only powered up when the caravan is hitched to the car. The monitor is hard wired into the ignition dependent circuit of the car.
Simples! Well almost
Sep 23, 2023
1,307
557
1,435
On the subject of hole cutters I've found "step drill bits" very useful in the past.They are able to cut from approx 4mm to 22mm on one bit,I bought a set of three from one of the well known German/Holland? Supermarkets,Very clean and accurate cut,,priced around £10...each cutting edge is etched with it's size.
Jan 9, 2018
22
16
18,515
My camera is Sikaflexed to the top rear at the rear of the van. To avoid drilling the body the wires take the short cut up to the roof then across the roof to the off side edge of the van. They are then fed throgh the off side "awning rail" to the bottom front of the van and underneath of the body to appear near the tow bar where they are connected to a grey plug. This way the wires are hidden from view. When I had my car tow bar installed and wired up the power feed was tapped from the fridge +ve and -ve (in the car) which is fed to a 7 pin grey socket on the tow bar. When the grey plug/sockets are connected they provide a robust connection between car and van. The video cable follows the same route round the van to the grey connectors. From the car tow bar the video cables are threaded through to come out on the dashboard. Power to the screen comes from an internal 12v supply. Obviously I have the normal 13 pin socket for the usual caravan supplies. The advantage with this arrangement is that it confirms there is a fridge supply.
Feb 13, 2024
1,226
786
1,435
Seems a bit of a palafa to me. Mine is on number plate, no wires, bluetoothed to screen in motor and vola, instant picture, no cables, no holes.
2,189
Do you have a link to that particular model?
Apr 8, 2019
47
27
10,535
Thanks - have you got any pictures?
Apr 8, 2019
47
27
10,535
thanks - have you got any pictures?
Apr 8, 2019
47
27
10,535
i tried this on my previous 'van, but found the camera was too low and provided poor field of view, so put it to the top. I'm interested in how the camera is powered, if you have no cables?
Sep 26, 2018
730
288
11,135
Beware of using Sikaflex... I would advise putting washers behind the base, that would enable you to get a cheese wire behind to cut it off.
An anecdote... A boatbuilder mate was asked to remove sheet winches from the side of a sailing yacht. The through deck bolts were removed but the winch wouldn't budge. It was reassembled, and a rope attached to a granite harbour wall, and the winch wound up... The outer glass fibre of the foam sandwich construction ripped off.
Feb 13, 2024
1,226
786
1,435
is it fixed to the back of your caravan? what's the transmission signal like - looks only a short distance on the website
I fixed, stuck it to my number plate. I have a Lunar Venus 7.93m length and tug it with a Kia Sportage, so a lengthy unit. I have drove out of sights , car only and the camera was still working for a good distance.
Reactions: fkeates
Feb 13, 2024
1,226
786
1,435
If you type in, rear view camera , in the search bar at top of page, you will see a thread all about it, pics included.
Reactions: fkeates
Apr 8, 2019
47
27
10,535
Just bought and installed it, I’m away next weekend so will report how it goes.
Initial thought pic looks good (at night and in the rain), but the angle the camera can be tilted by much is limited, but that is easily rectified.
Reactions: borderbilly
