Sargent Stinger 300
Jun 11, 2012
1,525
28
19,685
Hello Everybody. Happy New Year and all That . Has any body on here had to change a battery in the Stinger 300 also is it a specialist battery or is it a battery I can buy off the shelf? .
Sir Roger .
3,694
Hello Sir Roger, just bought a new one for our caravan as it was over 6 years old, ( recomended 3 years ) direct from Sargent, from them £44.99. Complete with switch on the board. E BAY same price but just battery.
3,694
Sir Roger, well at last I got around to fitting my new Sargent alarm battery to the caravan , just prior to the annual service, and on removing the original battery there was no switch on the mounting board, so the same as a basic Yuasa battery. Sargent was still cheaper though, have a good year.
Hutch.
Jun 11, 2012
1,525
28
19,685
Hi Hutch...Did you have to reprogram remote to alarm after changing battery.I thought I had read somewhere you have to reprogram .
Thanks for keeping me up to date .
Sir Roger .
3,694
Sir Roger, No I had no problem , old battery out new battery in, the plug is a bit fiddly, needle nose pliers needed rather than my banana fingers. No programming needed.
Here are the instructions I got from Sargent about reprogramming the fobs.
Learn the key fobs - locate and press the learn button
Referring to the diagram below, locate the learn button on the circuit board inside the alarm case.
Press and release the button.
A blue LED will illuminate next to the button to indicate learn mode, which will stay enabled for 20 sec.
Holding the new key fob about 1 metre away from the alarm system, press and hold the Arm / Disarm
button until the blue LED starts flashing.
Release the key fob button, the blue LED will start flashing faster to indicate a successful learn, and
then extinguish.
The procedure is now complete.
Repeat the process for any additional fobs.
LEARN
BUTTON View looking into the
top of the alarm
system showing the
circuit board
Reassemble the alarm case
Place the battery back on top of the alarm chassis in the same position as before removal.
Slide the alarm lid over the chassis,
Hutch
https://www.practicalcaravan.com/forum/technical/54143-sargent-310-alarm
Jun 11, 2012
1,525
28
19,685
Hi Hutch. My new battery pack arrived today and as you say complete with little switchy thing.Low and behold my pack has a label on it YUASA battery supplies .Thanks for your assistance along the way.
Regards Sir Roger
