Seasonal pitch advice.
2,238
Our Air Awning ( Kampa) went bang in a spectacular fashion when the stitching failed and the bladder herniated. It was 8 years old and beyond economic repair. To be fair it had benn left up for weeks at a time on a seasonal pitch in all weathers. Something that was specifically not designed for.
If Attwolls can’t help, I can recommend Specialised Canvas near Chesterfield who resized a pole awning for us.
Reactions: Jcloughie
5,311
If Atwools can’t help ,
John at Canvasworks should be able to do it . He’s at Leigh 4 miles from me.
He works from home and has repaired a lot for me over the years.
Reactions: toad a caravan
2,655
With the Isabella. It looks like I can get a whole new centre beam for £160. And it simply zips in. So all is not lost. At the moment there is no stock. But there is no hurry.
Today was a breezy dry day. Managed to get the awning dry on the lawn and to examine the damage. Luckily we had a son in law and later a grandson arrive to help with the lifting and folding. I told my grandson I could not work as fast as him. That’s because you’re old he rightly said. Leave it to me. 😟
The double stitched seam has completely gone. The bladder has not burst, but it feels thinner where is herniated.
2,655
I wrote to Isabella explaining what had happened. I vainly hoped they would write back to say the would send a free replacement as the seam should not fail. Well, as expected that did not happen.
But I have just received this reply which is very prompt.
Hi John,
Thank you for your message.
The part you need is part number 9x0000126, which is the C/M tube for the Cirrus. This comes as a complete unit, including both the bladder and the outer sleeve.
It’s a simple process to replace:
  1. Lay the awning out flat on its roof.
  2. Disconnect the isolation valves and the front inflation valve.
  3. Remove the tube completely, leaving the old bladder inside its sleeve.
  4. Position the new replacement tube in place and reattach the valves.
The tubes are £159 including VAT. Unfortunately, they are currently out of stock, but are due back in mid-November.
If you’d like to order a replacement tube, please contact your local Isabella dealer or use Click & Collect on our website: https://www.isabella.net/uk/accessories/details/isabella-air-cirrus-tube-c-m
If you need any further help, please let us know.
Quite refreshing to get full prompt response from a company.
5,228
Hi John,
Is there any point in replacing the tube if the stitching has failed?
2,655
The tube (bladder) is stretched, so would be silly not to replace it. I could get the stitching replaced and reinforced. But it would not be cheap. Isabella only do a complete unit, bladder and sleeve including valves and connections. Quite a complicated shape. I think £159 is reasonable considering. And less worry afterwards.
I need the blue part.
5,228
What I meant is there any point in replacing it until the stitching has been sorted out? Will Isabella be doing the stitching?
2,570
Hi John I think it very reasonable to get a replacement tube just need the stitching to come in at a great price .
2,655
Sorry, I must not have explained this very well in previous posts.
The tube is made up with a bladder inside a sleeve. It is the sleeve that has failed. My choices are. To have the sleeve repaired. Then to continue with a compromised bladder. Or, what I intend to do, get a new sleeve and bladder. In this way, no stitching will be needed.
9,041
Plus you get a brand new assembly which should be fine for a good number of years.
5,228
I think some of us assume the sleeve is part of the actual awning and the stitching had torn? I now assume that the tube goes into a sleeve and then the combination is then inserted into a sleeve on the awning? Please enlighten us. Thanks.
5,311
My old Kampa Rallye air is the same as Johns.
There are three parts to each tube.
1. The Inner actual air bladder. Mine was a thick polythene material.
2. The middle sheath into which the air bladder fits.
3. The main part of the awning which than houses the bladder and middle sheath.
Hope that makes sense😉
2,655
You have got it. 👌 I thought post 36 made it clear.
17
10
10,515
We have just gone seasonal. And yesterday we bought an Isabella Cirrus 400. It still needs putting up. We have a Bolon carpet for it, I know these are excellent. But we are looking for a bit more comfort underfoot. Some people on site have elaborate raised flooring. We are not going down that route.
One idea is to use interlocking foam tiles underneath, not sure how successful that would be, and I can’t find the big ones anywhere, just 2 foot square. That’s s a lot of tiles.
Amazon do budget breathable carpets, £29. But open to all suggestions.
Hi, I have been using the 60 x 60cm interlocking tiles for years but only on hard standing pitches, my Isabella awning is 3m x 2.5m it takes 20 interlocking full tiles, not right to the edge but you then you don't walk along the edge of your awning. Flatten any stones as you lay the tiles, once done then lay the expensive carpet , theres no need to put anything under the tiles, carpet is protected and can walk in stocking feet, when removing just wipe any damp tiles down before storing away, I use one of those garden bags with a handle each side then using a cable tie to tie handles together, I store the bag on its side in the shower room while travelling.
