- Feb 13, 2024
- 1,392
- 883
- 1,435
My 68 plate sportage tpm,s are very sensitive, one wheel dropped 1 psi, suspect due to cold weather and threw up the dashboard warning ⚠️ light. Anyone else have the same?
It's not TPMS sensitivity - it's Boyles Law - the tyre pressure will naturally drop 1 psi for each 6 degree C drop in temperature - some places have had a 12 degree change from last week to this.My 68 plate sportage tpm,s are very sensitive, one wheel dropped 1 psi, suspect due to cold weather and threw up the dashboard warning ⚠️ light. Anyone else have the same?
What you don't state is how close to the lower limit the tyre was before the temperature dropped.My 68 plate sportage tpm,s are very sensitive, one wheel dropped 1 psi, suspect due to cold weather and threw up the dashboard warning ⚠️ light. Anyone else have the same?
My fronts are 33psi per VW. Drop to 32 the warning comes on. Drive a while and back to normal.What you don't state is how close to the lower limit the tyre was before the temperature dropped.
Always do mine when the car has not been run, and there’s no sun on the tyres.My fronts are 33psi per VW. Drop to 32 the warning comes on. Drive a while and back to normal.
We are told never check tyre pressures when hot🙀
Set at 33, front left alarmed at 32, drove 20 miles and still alarmed. Put a couple of pounds in it and it cleared.What you don't state is how close to the lower limit the tyre was before the temperature dropped.
I just set mine at 33psi all year around depending on weather conditions in summer or winter. Never had any spurious lights ever.Then general rule for tyre pressure is 2 psi for 10 degrees differential. So if Winter temperature when cold is 10 degrees lower than the tyre cold pressure in Summer they need 2psi adding to prevent the monitor light coming on.
Many TPMS sensors actually step in increments of 10 kPa and this is then converted electronically to the nearest whole psi. 10 kPa is about 1.45 psiSet at 33, front left alarmed at 32, drove 20 miles and still alarmed. Put a couple of pounds in it and it cleared.
3.2 bar seems high when not towing, what is the towing pressure?I set my tyre pressures when there is no sun on the vehicle to 3.2bar all round if I'm not towing.
I then press the reset button on the dash, I believe it's standard fitment on all VAG cars with TPMS. This calibrates the system to the new pressures.
Actually it doesn't as the system has not a clue what the pressure is it's all done on rotation of the wheels using the ABS sensors. It just resets the system to the base point and if one wheel has different rotation characteristics then it sets off the TPMS warning.
Numlexia strikes again should be 2.3bar.3.2 bar seems high when not towing, what is the towing pressure?
Some cars have TPMS sensors in each tyre valve - others use the ABS sensors to measure rotational speed - the two systems are completely different - VW Group (VAG) cars use both methods depending on model.I set my tyre pressures when there is no sun on the vehicle to 2.3bar all round if I'm not towing.
Do the non ABS ones still have a reset/relearn button?Some cars have TPMS sensors in each tyre valve - others use the ABS sensors to measure rotational speed - the two systems are completely different - VW Group (VAG) cars use both methods depending on model.
No - at least my Touareg doesn't although there is a menu option to select full load pressures or normal - generally, the ABS-type TPMS is fitted on cheaper models but the 3rd generation Touareg, from 2018, uses the cheaper type along with other decontenting - I don't know what the equivalent Audi, Porsche and Bentley models use.Do the non ABS ones still have a reset/relearn button?
I've not seen the tyre valve type as I've only owned the bottom end Skoda brand.
My car has the ABS sensor system, its worse than useless! It has never yet picked up the low pressure warnings my Tyre pal overmarket dustcap replacement external sensor system has (correctly) alerted me to.Do the non ABS ones still have a reset/relearn button?
