Good luck with "The Wiggle method" lets hope it works.. and the flying display at Fairford should be good, last flying display for me was when I retired, 1 .5 hours left seat in my S92 Helicopter. 8 years ago.
Glad you have solved it. If all else fails though, pop round to DD’s and keep your beer there. Make him promise not to drink it though.Good news Chris 👏. In the interim spray liberally the switch internals best you can with Electrical Contact Spray. We live six miles from Fairford.
I can understand your frustration with the intermittent operation of fridge, and why its been important to try and find out what has been causing it. Assuming you have found the problem, you report a "selector switch" seems to be the culprit. Now I'm not clear on what you are referring to, and the other part of your comment where you say you have bypassed it, and if you need to turn the appliance off, you will need to use a remote isolator valve.
This sounds as though you may have bypassed the fridge's gas control valve and in doing so you will have removed a very important safety feature - the Flame Failure Device or FFD.
If I'm correct, it means the gas will flow to the fridges burner as long as the remote isolator valve is turned on. Crucially if the flame should go out for any reason, the gas flow will not automatically stop - you have an uncontrolled gas leak.
DO NOT USE THE FRIDGE IN ANY WAY.
That is not only highly dangerous from a safety perspective, it is a criminal offence.
Thank you for the clarification, As a now retired gas engineer and having had to deal with gas systems where people had been injured (in one case nearly killed) by ill informed tampering, I know how important these things are. Many people are often surprised to learn that it is actually a criminal offence, and can result in custodial sentences to interfere with any of gas appliance's control or safety related parts.calm down John, you have misunderstood. The thermocouple operates correctly. Turn the gas off and the flame goes out, valve shuts. Turn the gas back on and no gas is flowing. What I have done is no different to having the switch on the gas setting.
I appreciate your concern. I imagine you’ve seen it all to use a cliche. I know my limits when it comes to gas and would certainly never bypass a safety device. I will be replacing the selector switch myself as I know it’s well within my capabilities, but won’t be mucking around with the valve it’s self if that turns out to be suspect. I’m pretty sure the issue is the switch. It’s apparently a common issue and you quite clearly hear the clunk of the solenoid disengaging when you wiggle the switch about.Thank you for the clarification, As a now retired gas engineer and having had to deal with gas systems where people had been injured (in one case nearly killed) by ill informed tampering, I know how important these things are. Many people are often surprised to learn that it is actually a criminal offence, and can result in custodial sentences to interfere with any of gas appliance's control or safety related parts.
Well it’s always the last thing you try isn’t it?!That’s what I suggested 2nd June 🙂 switch Earthexercise the switch
Yep, it’s a 6 way for mine.Thetford do a 5 and 6 way switch, did you get the right one?
Pretty sure it does! I can always leave my phone in there recording to be sure.Glad thats working, now you need to know if the fridge light goes out when you shut the door. ???
Don't worry about a thread carrying on, at times thats how folk find out stuff.
