- Feb 6, 2024
- 130
- 33
- 585
I know this an old topic dating back to 2009 when I was just a nipper, but what is the current thinking, I used Puriclean but other's say they use Milton, will it really damage the metal parts of the boiler.
I used Milton in the old days but never left it in more than 30 minutes. There wasn’t much choice. But I then moved to Puriclean and if I was starting out afresh I’d go for Puriclean.I know this an old topic dating back to 2009 when I was just a nipper, but what is the current thinking, I used Puriclean but other's say they use Milton, will it really damage the metal parts of the boiler.
Actually I think the question was about which was best to use?Never used either, after 25+ years of motorhomes and caravansv I'm still here.
And the option of using neither is also a choice.Actually I think the question was about which was best to use?
There are chemicals in the likes of baby bottle sterilising fluids that can attack some metals, so its essential to follow the instructions regarding strength and exposure time. But also check the instructions for the water heater and any other metallic fittings regarding cleaning and sterilising.I know this an old topic dating back to 2009 when I was just a nipper, but what is the current thinking, I used Puriclean but other's say they use Milton, will it really damage the metal parts of the boiler.
That is true, but the OP was asking which was the best option i.e. tablets or fluid.And the option of using neither is also a choice.
You are wrong, both stearilising products come in liquid and tablet form.That is true, but the OP was asking which was the best option i.e. tablets or fluid.![]()
Why am I wrong? Totally mystified?You are wrong, both stearilising products come in liquid and tablet form.
Puriclean for me.
The original poster is asking about puri clean or Milton. Not tablets or fluid.Why am I wrong? Totally mystified?
My question is - By using Milton will it damage the boiler or is it a myth?The original poster is asking about puri clean or Milton. Not tablets or fluid.
As I said both products come as tablets or solution.
I wonder if those who do not use any solution or method would be so sure if they saw the insides of the pipework and tanks and the algae growth.
I always used Puriclean. But found it left a taste. And when heated it could be smelt. So I developed a method. I made a strong solution and swirled it around the aquarols over about half an hour. I also filled the system up and left that.
I then did a proper job of swilling the system through.
But I only did this at the start of the season.
The advice I got was to leave the Puriclean in the pipes and aquarolls overnight and flush the system through until the water didn't feel filmy, but we don't drink it so I don't worry about taste.
MikThat is true, but the OP was asking which was the best option i.e. tablets or fluid.
Milton is absolutely fine for aquaroll as my kids are 50+ and their early years food and drink utensils were sterilised with Milton. Nappies too probably but I didn’t go there.My question is - By using Milton will it damage the boiler or is it a myth?
I used Puriclean, but someone on another group chat was questioning what to use, I suggested Puriclean, other's say they use Milton, I just wanted to get current thoughts on whether Milton really shouldn't be used.
On a different note we haven't been using the aquaroll water supply for hot drinks, we take filtered brita water in a container from home, but I steralise that container with Milton before every visit, cos in tablet form it's so easy to use.
Given its temperature range of 25-45 deg C for growth it’s highly unlikely to develop in an empty Aquaroll stored over winter. It’s spread by aerolised water or soil, the latter quite a rare source of infection, and has to be inhaled ( most common) or aspirated.Are you saying legionnaires cannot exist in an aquaroll that has been stored over winter?
It can thrive in the ground, soil , or any damp area . Not dissimilar to pneumonia.
Anyway the point was and is simple.
I personally will not drink water from an aquaroll that has been stored for a period time .
Common sense tells me that any residual,water left inside may become contaminated with any number of bacteria or virus and it is therefore sensible to clean the aquaroll with the appropriate cleanser.
I had a truma pump fail so took the assembly to bits to replace the actual pump. The hose and cable that run inside the blue sleeve were pretty disgusting (as was the inside of the sleeve) even though I leave the pump in the aquaroll to soak for an hour or two when sterilising the system.While folks are discussing steralising water systems, it's also worth doing your Aquaroll filling pipe, the insides of those can sometimes make a sewer look clean!
Have you ever taken a childs school drinking bottle to bits, they grow black mould inside them.I had a truma pump fail so took the assembly to bits to replace the actual pump. The hose and cable that run inside the blue sleeve were pretty disgusting (as was the inside of the sleeve) even though I leave the pump in the aquaroll to soak for an hour or two when sterilising the system.
