Toilet wast
Dec 2, 2018
16
Got the caravan out today ,going away this weekend I pulled the toilet wast and it felt jammed ,came out with a good pull ,is there something I should grease.
1,528
This is not going to be very much help...but we had a similar problem. The guy who does our mobile servicing looked at it and fixed it. He said that he had “reset it” and it didn’t need any parts so charged us very little. Works great now. Unfortunately we were not there when he did it so cannot say what he did, but I don’t think it involved greasing anything. Told you it wasn’t much help but if you google resetting a caravan toilet it may throw light.
44
if you didn`t close the blade from inside the van and pulled the holding tank out with force then you have moved the mechanism under the bowl,maybe even stripped some fixings.
Sep 29, 2016
1,816
235
I can't help but think that Burn has made a valid observation.
6,954
Totally agree. Never tug it out as something will break. Always go back and check the blade is fully shut.
1,528
I suspect that is what had happened to ours and resetting it involved sorting out the under bowl mechanism.
3,993
Sounds like the usual blade mechanism failure. The blade , cheap plastic, has a small cog moulded on the underside . This is moved by the blade arm piece which operates when you move the open / close lever at the front of the toilet bowl.
The part is circa £6.00 and freely available. I carry two spares . They have rescued Woosies at previous meets!
Yet again a very poorly cheaply designed caravan product. Better materials would certainly help.
Also agree with the other posts. Do not force it or you will cause more expensive damage.
Which model of toilet have you?
1,818
Have to agree with the rest, I have never had any problem pulling out the toilet over many years, except on a couple of instances when the blade had not been fully shut.
May 24, 2014
3,687
765
I am wondering if the OP simply tried to pull it out via the orange handle rather than lifting the orange handle to unlatch it.
3,326
Good point there Thingy, I have been caught out by that.
Dec 2, 2018
16
Thank you for the advice, been back in the caravan and I checked the blade was shut ,but there seems to be another click after closing the blade, it seems to be a lot better.
