Towing a Hymer 390 with a CRV - or not
macandy
BANNED
Jun 12, 2014
78
18,585
Hi all…
Having taken the plunge and bought a caravan, a Hymer 390, rather surprised to find my CRV is not man enough to tow such a small caravan. For real? 1,200kgs? Even the Honda dealer was surprised when I told them the 'ideal tow car' they sold me can't tow the skin off a rice pudding, they thought it was rated at 1,500kg
So… can any of you experienced people help me out here with all this MIRO, payloads, MTPLM and stuff?
2003 CR-V auto 1,200kg and 60kg (this magically increased to 1,500kg and 100kg six months later - checked with the dealer, no difference in the suspension, same part numbers)
Any mods to the car? Bigger wheels off a newer CRV and spring assisters as I sometimes carry things like 300kg car engines in the boot.
MRO - 1050kg
Payload Hymer quote 150kg, 300kg and 450kg?!?!
MPTLM - 1,350kg
Max nose weight 100kg
So I suppose the question is.
Chuck everything into the car, keep the caravan light, keep the nose weight at 60kg and it will be good to go?
Any advise really appreciated, but I have a sneeking suspicion I'm going to be looking at a newer CRV that is officially rated at 1,500kg?
Feb 3, 2008
3,790
First things first - what does your CRV's registration document (V5C) say about the vehicle?
What is its Mass In Service?
What is its Max permissible mass?
What is its Technical permissible maximum towable mass of the trailer (unbraked)? Edit - should have said 'braked' not 'unbraked'
What does the car's handbook say for nose weight?
What is the car's gross train weight, given on a plate on the door pillar?
With the above figures we can then help you.
macandy
BANNED
Jun 12, 2014
78
18,585
No V5 to hand, (at work), but the plate in the engine bay says 1,960kg and 3160kg, kerb weight IIRC 1,486kg. Nose weight in 60kg
Feb 3, 2008
3,790
As I understand it the VIN plate gives the following:
Top to bottom: -
Max Gross Vehicle Weight
Max Gross Train Weight
Max Front Axle load
Max Rear Axle Load
so I'm not sure which figures you are quoting.
macandy
BANNED
Jun 12, 2014
78
18,585
Top to bottom: -
Max Gross Vehicle Weight - 1960kg
Max Gross Train Weight - 3160kg
Max Front Axle load - 960kg
Max Rear Axle Load - 1020kg
Hope this helps :)
Feb 3, 2008
3,790
The difference between the first two weights is generally the max permissable towed weight, which in this case is 1200kg (3160 less 1960), but you need to confirm with your V5 certificate. If this is your max towed weight then your car, unfortunately, cannot legally tow your van with an MTPLM of 1350 kg.
Edit - my first reply to you should have said 'braked' rather than 'unbraked'. :blush:
macandy
BANNED
Jun 12, 2014
78
18,585
Many thanks, all makes sense now.
Still very annoyed that the dealer 'These make great tow cars' was completely oblivious that Honda derated the 2nd Gen CRV autos. :unsure:
Ah well, time to change the car methinks.
3,129
The difference between the first two weights is generally the max permissable towed weight, which in this case is 1200kg (3160 less 1960), but you need to confirm with your V5 certificate. If this is your max towed weight then your car, unfortunately, cannot legally tow your van with an MTPLM of 1350 kg.......:
Hello Woodlands. Your statement is not correct. The difference between the GTW and the GVW cars towing limit represents the guaranteed weight the vehicle could tow. The MTPLM is not a weight but a weight limit a subtle but important difference. the car could legally tow any trailer provided its actual weight does not exceed the vehicles specification even if its MTPLM is greater.
Of course you also have to consider id the combined MAM might be a problem for your driving licence categories .
macandy
BANNED
Jun 12, 2014
78
18,585
so as long as I ran the van over a weigh bridge and it was 1,200kg or less, I'd be OK?
Licence is not a problem, passed my test in 1976.
3,129
Subject to the Max braked towed weigh that Woodlands is asking for your contention is basically correct. It would be unusual for the BTW to be less that the difference between GTW - GVW in your case 1200Kg' but you must check the documents.
macandy
BANNED
Jun 12, 2014
78
18,585
Which has me in a bind, as these weights are not listed on my V5 , all I have is the plate in the engine bay...
Caravans are confusing stuff. :(
3,129
Such web sites cannot be used as definitive information. Use the data plate on the car which should have the Gross Vehicle weight and Gross Train Weight the difference being the allowable towed weight.,
To be honest, if the difference between the Grow Train weight and the Gross Vehicle Weight is 1200Kg then you should be legal to tow as long as the trailers actual weight does not exceed 1200Kg
And in fact you can add you nose weight to that so technically you can tow a trailer whose weight is 1200+nose weight Kg. as the nose weight is not towed it is carried by the car.
macandy
BANNED
Jun 12, 2014
78
18,585
Well Honda are looking a bit sheepish, my towing limit is less than a Jazz which is clearly rather stupid for a big 4x4, so we are discussing a 'generous' trade in allowance for exactly the same car, a 2004 auto, but plated at 1500kg.
3,129
macandy said:
Well Honda are looking a bit sheepish, my towing limit is less than a Jazz .....
I have had a quick look at a data base (note my reservations above) and the biggest braked towed weight for a Jazz is 1000Kg where as your CRV is 1200Kg!
Mar 13, 2007
1,750
well it could be worse a 3 litre V6 odyssey is only 720kg
macandy
BANNED
Jun 12, 2014
78
18,585
Was just being a bit rhetorical. Having said that, towing 1000kg in a CVT Jazz would be a losing game. Had a CVT Honda, box is at the limit without anything hung off the back - killed one.
3,129
macandy said:
One of the more popular databases quotes the old Mk1 CRV 2.0 auto at 1,300kgs... :huh:
You can't trust data bases. They do contain errors or don't contain all models of all cars or caravans. The problem is you don't know which bits are right or wrong. The authorities and therefore you will always go by the vehicle registration documents or information specifically related to the Vehicles VIN number.
2,086
And the DVLA database also contains errors - but that is what the Police and VOSA will rely on.
macandy
BANNED
Jun 12, 2014
78
18,585
All good fun, isn't it? My plated weights are 30kg heavier than the figures the dealer got off the Towsure database for the sales paperwork.
Dealer was top though, gave the same advice as your good self, run the car and the caravan over a weighbridge and get the weights checked.
