Hello
I hope you can help me. I have several problems with my caravan water system. It is a pressure system with the addition of an internal onboard water tank fitted by Glossop Caravans when I purchased it from new. The caravan is now 12 years old. it is an Elddis Odyssy 634.
When the pump is on the internal position at the control panel.
The water flows through the taps. However, when the tap is turned off the pressure switch still makes a clicking noise. Even when the adjusting screw is removed completely.
The orange light on the control panel remains on when it is in the middle (i.e. off). The clicking stops when the panel switch is in this position.
When the pump is on the external position and middle positionat the control panel
The internal tank fills but does not stop when full.
The water flows from the tap but not at the same flow rate as when on internal.
I have had a mobile caravan fitter out to service the caravan and look at the water system.
The following have been replaced:
- the pump in the internal tank
- the pressure switch
- the solenoid
- the top float in the internal tank
He changed one of two inline floats in the onboard water tank and now the tank does not stop filling up. The inline float does not appear to be working.
I hope someone can help.
- the solenoid
