- May 1, 2005
- 4
- 0
- 0
Hi
Hope someone can offer me some help. I have purchased a used ABI Award Daystar MK2 year 1990 and am towing this with a Hyundai Santa Fe 2001 which was fitted with all the Witter towing equipment. All appeared OK and have made two trips but have been concerned that the caravan battery was not charging from the car so have had to replace the battery. I have checked the wiring of both the caravan and the car and found that the car has the newer wiring and the van the older wiring which I now understand will not charge the caravan battery. The problem appears to be with the tow bar socket pin 4 which has auxilliary battery charging and live feed, this checks ok. The van plug has pin 2 for auxilliary charging and pin 4 a permanent live feed. I have changed the position in the caravan of pins 2 AND 4 and the charging works. Can anybody offer me further help - I have checked the Haynes manual??? Is there a quick-fix solution to the 12S problem of new/old? Thanks in advance.
