- Mar 14, 2005
- 19,261
- 4,438
- 50,935
Whenever you leave a battery standing it will eventually lose all its charge, the question is how long will it take, and that depends on the design of the battery and its condition. and its state of charge and the temperature of the storage location.Ok woke up this morning and the Noco is at solid green light.
Just out of curiosity, when I disconnect the charger from the battery, there won’t be any loss of power while it sits in the garage?
Another question to consider is how do you test the state of charge? Most people would use a voltmeter and as a guide a fully charged 12V lead acid battery should show a terminal voltage of 12.6 to 12.8Vdc The charger should be disconnected for at least 2 hours before this measurement is made.
If the terminal voltage is down to 12.2Vdc the battery is at about 50% state of charge
If the terminal voltage is less than 11.8Vdc the battery is considered to be fully discharged and should be recharged as soon as possible.
If the terminal voltage is below 10.5V dc, and has been standing form more than a couple of weeks, a 12V battery may have suffered permanent damage and should only be recharged under supervision with a smart charger.
In practice a typical 100Ah 12V lead-acid battery, when fully charged and disconnected, experiences a self-discharge rate of approximately 3 to 6% per month
