Do I really need a gas bottle
Status
Not open for further replies.
Jul 15, 2008
3,813
951
My question was quite simple, what is that black hose with the cap on the end all about?
.........the caravan main gas fittings and pipework are fitted to the bodywork of the caravan and end in the bulkhead regulator.
The black hose joins a gas cylinder to the bulkhead regulator. There are different types of gas cylinders available with different fittings required to attach the cylinder to the black hose.
If you are permanently on a pitch and don't want a gas supply then the black hose and cylinder connection is redundant.
Jan 20, 2023
1,139
980
2,435
Thanks, should I remove the bit at the end of the pigtail and just be left with a nut at both ends
No, buy the correct pigtail from an accessory shop, they aren't expensive, as others have said, one end will screw onto your bulkhead regulator and the other onto your gas bottle. All straightforward but remember that the fitting that screws onto the gas bottle is a LEFT handed thread. This is mine, the black item is a newer version of the bulkhead regulator that you have, the other screws directly onto the cylinder.
Sam Vimes
2,210
1,759
Gonna be on a seasonal pitch on ehu, we only plan to fry bacon and eggs, maybe do sausage and mash and a chilli nothing fancy, the sausages could done in an air fryer.
Do I really need a gas bottle, feel a bit edgy about using one being a newbie.
I can understand your caution about using a gas bottle but these are used on thousands of touring and static caravans and motorhomes and boats. The number of incedences of problems on these is probably very low - but then again you don't want it to be yours it if happens :)
Our community doesn't have access to mains gas so many of us use bottled gas for things like our gas hob in the house. Two 19kg bottles sit outside and are connected in a similar way to the caravan.
I think you'll be ok with gas and a little restricted without it.
3,911
For Richtee's information:-
GaryB's picture shows a bulkhead regulator with a flexible pigtail for connecting a PROPANE bottle, which has a different connection to the BUTANE cylinder on his own fittings.
Richtee you need to ensure you have the correct pigtail for the type of LPG cylinder you have. Propane cylinders have a male "POL" connector
Butane cylinders come in two types Dumpy bottles and older larger Butane cylinders use a female (the larger end)
More recent larger Butane use a clip on device
Which is the device you already have, combined with the correct pigtail.(Above)
Clearly from your questions you are unsure about the gas system you have and how to use it. I suggest you arrange to take a caravanning course run by caravanning clubs, as they take you through the essential working and safety processes, and doing it first hand you would learn a lot more from competent tutors.
4,598
Does post #21 show a butane connector in the photo?
Status
