The outlets from my caravan waste (2) are approximately 28mm in diameter, what size of flexible pipe do I need along with fittings?
Thank youIf you google 'caravan waste fittings' and open one of the sites you will find these are available in 23.5 or 28mm sizes. The waste pipe is 28.5mm and other fittings, like outlets etc 28mm which should meet your needs.
The set up I have now is two 28mil flexi pipes goi g in to one but like he says in his video it does not take much for them to spring out, seems a good set up for. £5.79,
