Insurance and the 85% rule
Page 6 - Passionate about caravans & motorhome? Join our community to share that passion with a global audience!
Hello again Allan,
You have made several references to Newtons Laws. To be clear on what we are saying I quote published texts:
First law:
Every body continues in its state of rest or of uniform motion in a straight line unless acted upon by some external force.
Second law
The rate of change of momentum of a body is proportional to the applied force and takes place in the direction in which the force acts.
Third Law:
To every action there is an equal and opposite reaction.
All three laws are relevant to the braking issue.
We accept that braking is a force, which acts against the velocity of a body. It does this by causing friction between the moving and non moving surfaces.
The degree of friction is controlled by modulating the pressure between the friction surfaces.
The amount of energy attributable to a moving mass is defined as the mass x its velocity otherwise known as momentum.
In the context of the arguments in this thread, we assume that the different vehicle masses are travelling at the same starting velocity before the brakes are applied.
if a laden vehicle has twice the mass of the unladen vehicle then from the laws above their respective momentums will be in the same ratio i.e 2:1.
If both vehicles had the same braking force applied, then the laden vehicle will take twice the distance to stop.
In the real world the braking efforts would not be the same, because, as has been stated else where the maximum braking effect occurs when the wheel is just about to loose grip (i.e skidding) So to achieve that operating point so the wheel does continue to turn, the pressure in the braking system is modulated either by an ABS system or by the driver.
It is now important to understand that the grip between the tyre and the ground is dependant on the down force pushing the wheel to the ground
For the unladen vehicle there is less mass for gravity to act on, thus grip quotient is less than for the laden vehicle.
So whilst the heavier vehicle has greater momentum, and will need to convert more energy to heat, it is also the case that because of the greater weight force, more braking effort can be applied, so the same vehicle both empty and laden can achieve the same stopping distances.
In addition to this, for most vehicles as the load is increased the centre of gravity is likely to rise. Under braking the mass tries to tip forward and the higher it is the great this effect is. It has the effect of transferring some of the weight to the forward axle, and this allows even more braking force to be applied thus improving retardation.
There are some riders to this:
All elements of the vehicle should be designed to cope with the maximum load and work duty.
The braking should be done in a straight line.
The driver should be able to apply sufficient force to the brake system to achieve the retardation rate.
The driver must be conscious of the load and the ability of the vehicle to contain the load under heavy breaking.
Clearly if a breaking system cannot cope with the mass, then stopping distances would increase, but also the vehicle is over loaded.
All this is fine in theory, and under ideal conditions the theory could be demonstrated, but most road conditions are not ideal, so it is sensible to give large vehicle more space for braking.
Just the same advice as all them motoring people suggest, leave a bigger gap cos it takes longer to stop with all that extra weight, had a look on that rospa web and they say the same, loads of technical stuff about caravans too, but none of them seem to praise caravan brakes and seems to be the rule of thumb to make the gap bigger.
berty
Maybe Caravans work differently in Australia _
"Is braking with a caravan or trailer in tow any different?
Yes, even though brakes are required on all trailers over 750kg, the extra weight must always be allowed for.
Towing a caravan means allowing a safety margin of an extra 20 m or more over your normal stopping distance, more or less according to speed.
Most modern caravans have electronically-activated brakes adjusted from the driver's seat through a controller. They should be adjusted to ensure the caravan's wheels won't lock.
Braking performance changes completely when the road is wet or the surface broken.
On steep downhill runs, save your brakes from overheating by selecting a low gear and using the engine's braking potential.
Never ride the brakes for long stretches. Caravans have drum brakes - let the pedal up and give them a chance to cool"
And Vauxhall/GM UK said
"When coupled to a caravan/trailer the
vehicle requires more braking effort when
driving down long gradients, so select the
same gear as you would driving uphill and
drive at roughly the same speed. With
automatic transmission engage drive
range 3, 2 or even 1.
Select D again as soon as driving
conditions permit.
If it is necessary to apply the brakes fully, in
particular to ensure short braking
distances when towing a caravan/trailer,
depress the brake pedal as hard as
possible.
Remember that the braking distance for
vehicles towing caravans/trailers with and
without brake is always greater than that
for vehicles not towing a caravan/trailer."
I never found that one Chris, but it seems like they say the same thing down under, I don't drive a Vauxhall but I do have an automatic so I will do like they say and put it in l or 3 going down a hill. And if you see a car and a caravan out in summer with enough room in front of me on the road for 6 buses to fit in to you will know it's me. Better safe than sorry.
berty
A car is no heavier just because it is towing. Only if the caravan is pushing well in excess of the force required to operate the overrun brake do the car's brakes have to do any more work. This could happen, for example, if the caravan's brakes have faded, such as on a long descent. That is why I have installed a thermocouple on the caravan's brakeshoes linked to a warning buzzer inside the car. As soon as the temperature of the brake shoes exceeds 140
Lutz. You truly are a star!
People here will not put a pop stud screw in their caravan for fear of voiding a warranty and then after all the dabates re braking you have fitted a "thermocouple" to your brakes as you are aware that there could be a problem.
For most caravans brakes to work, load has to be put onto the coupling with the tow ball shaft pushing back and applying the brakes so the tow hitch becomes more or less part of the car with the caravan sliding onto it with the force activating the cables rods to the brakes.
Now I realise that the car does not instantly gain weight as if its eaten 3 Big Macs with large fries in an instant, but in my simple humble opinion weight / force must transfer to the car and to keeep the brakes applied some weight/force has to continue to be applied to the car until the brakes release.
Firstly, as you may or may not be aware, in Germany any technical modification to a vehicle or trailer must be approved by the equivalent of the MOT. They certify roadworthiness of all changes so that any warranty is automatically upheld, too. Approval was given to the fiiting of the thermocouple at the same time as I had an electronic stabiliser installed.
Secondly, the horizontal force required to operate the overrun brake is minimal, probably in the order of 30kg, which is hardly going to put much added load on the car's brakes.
Thirdly, because the centre of gravity of the caravan is considerably higher than its axle(s) it will tend to dip under braking. Therefore, the resultant force that is transferred to the car by the caravan under braking will primarily be vertically downward on the towball, benefitting the efficiency of the car's rear brakes (so we're back to the old topic again), and to a much lesser degree a horizontal one.
I'm aware of the differences between UK and Germany Lutz, but this site covers mainly what is used and produced in the UK.
After debate elsewhere here re T/A axles and S/A caravans I find your attitude to some of the points made even more incredible and quite rude.
I mean that as a personal observation and not as an attack. It is proven fact that caravan and trailers have similar towing characteristics whatever you may think. Scienific tests have proven that lower C of G aids caravan stability that in turn offers more safety. Lower profile tyres also improve handling and twin axles assist straight line stability and reduce the potential of snaking. Also 4 wheels and brakes take the loads off of just two sets of bearing and brakes apart from anything else.
For whatever reason you make comment about caravanning in general queerying about data and evidence when you have opted to take extra measures to assist you own caravans braking and stability.
From experience of towing similar weights on single and twin axles despite differences in hub and wheels sizes I've always found twins hubs and brakes to run cooler. May be my imagination, but I think not.
Your observation re weight / force transfered to the tow car I believe to be somewhat optimistic and also to rely on the caravans brake and tyre grip being equal to the cars.
I also find the 140 c thermocouple a bit of a strange measure. That temp seems quite low to my memory as I seem to remeber thay operating pad temps for drum brakes are often 200c plus with brake fade at around 400c unless competition type pads (not something I'm aware of for caravans) are fitted.
How you can balance other comment re cost of an extra axle re cost of electronic stabiliser, thermeocoupling and the testing I'm lost for.
I would say that the measures you have taken re additions to you van to be ones I may have considered from experience in towing S/A vans but not from experience with T/A vans.
How one can expect to be able to pull over when a brake temperature warning comes on I'm not sure as roads as conditions can be so different and it is not always possible to stop say coming town from a mountain road in traffic.
There are other issues to consider but this is rather boring for others as they have already remarked.
What ever the data re braking with a caravan and a car equipped with ABS it still relies on many factors re the caravans braking and handling for it to work every time.
There have been many warnings for drivers with ABS not to expect shorter braking distance than non ABS systems and to peddle a belief that one may stop quicker with a caravan in tow when you have ABS on the tow car may lead to a dangerous false sense of security for some tow car drivers especially when so many motoring organisations advise to lengthen braking distance when towing.
I only mentioned the issue concerning approval in Germany because of your surprise at my apparent laissez-faire attitude about fitting a thermocouple to brake shoes. Actually, they were included in the kit of the electronic stabiliser.
I fully agree that a lower centre of gravity can only be beneficial but I think you would also not dispute the fact that the centre of gravity of a caravan is above axle height, no matter what measures have been undertaken to keep it as low as possible. As this is the case, the caravan will always tend to dip when braking.
I will not comment further upon single axles vs. twin as this has been done sufficiently elsewhere.
If you think 140
So there we have it, every motoring organisation the length and breadth of the country, and as far field as Australia quite rightly suggest when you increase the weight of your vehicle,wether towed or otherwise, Increase your stopping distance, simple rule of thumb. But like lemmings, a lot of people on this forum would choose to ignore this very important advice by organisations in the know, for a person called Lutz, who for the majority know very little about him, and bases his theory of a shorter stopping distance when towing, than driving solo, on an article he and two others have read in a magazine somewhere that cannot be substantiated, even in title! And he expects us to believe these rather dubious to say the least findings in preference to an organisation called ROSPA, who carry out there research in the interests of safety,and who have proven beyond doubt that weight increase's stopping distances. And finally this one makes me smile " That is why I have installed a thermocouple on the caravan's brake shoes linked to a warning buzzer inside the car. As soon as the temperature of the brake shoes exceeds 140
"an article" ...... "that cannot be substantiated, even in title" is a gross accusation. You have not given me a chance to locate the report. Where is the report from ROSPA? Why should a statement made by ROSPA be any more credible than that made by another institute. With due respect to ROSPA, but they don't have sole rights to the whole truth. It is possibly quite valid that under different circumstances both could be correct. One would have to have full details of both sets of testing conditions. Consequently, if I am to provide full details, it would only be fair to provide the same that led to the ROSPA (or anyone else's) findings and compare them.
Regarding the warning buzzer to indicate brake fade, of course it would be of advantage to have one on the car, too. However, the thing is that brake fade on the car can be recognised much more easily than on the caravan so a warning system for the caravan is perfectly justified. Besides, the warnign system is not my creation but included in the manufacturer's kit of the electronic stabiliser.
How you can have the blazen audacity to say that you have proven your point and the discussion can therefore be closed is the peak of insolence.
You made your statement almost three weeks ago Lutz, more than enough time for you or any one else to substantiate your findings. No Lutz I am not comparing ROSPA with any other institute, I am comparing them directly to the advice that YOU gave out on this forum. And regarding the buzzer for brake fade I would feel embarrassed to admit that I had had to resort to fitting one, you should never ever put yourself in a position where you suffer from brake fade, and if you do, that is down to poor driving technique, and not being able to recognise brake fade without the aid of a buzzer is truly beyond me.
"How you can have the blazen audacity to say that you have proven your point and the discussion can therefore be closed is the peak of insolence".
No the peak of insolence is your very dangerous and misleading advice in the first place, from a man who admits that he needs a buzzer to warn him when his brakes on a towed trailer are not working...........I rest my case.
Allan.
Lutz and I and others here are not always at a home base.
I disagree with Lutz on some matters, but he has axplained that the thermocouple is part of and anti snaking device that works by utilising the caravans brakes as opposed to the blade of a Scott style stabiliser or an Alke to ball friction type that you or I may use.
I see no reason for you I or any one else to doubt what Lutz and others have said, I'm pretty sure that the report is not a blanket ABS with caravan in tow stops shorter every time but lets not lower this to back street thugery.
I think it is fairly obvious wether you are in England or Germany it will take you longer to stop if you are towing a caravan than without one. And because this confused me so much I phoned the caravan club up and there advice is to leave yourself more room to come to a stop when you are towing. Lutz should not be so rude to some one who has pointed out that he has made an error, it takes a man to put his hands up and say sorry. we all make mistakes sometimes lutz and most of the advice you give on here is usually very good, but it is best to play safe when it comes to safety related topics. So now you two kiss and make up.
berty.
I quite agree with you Cris, and it is a point I made earlier in my postings that all combinations of car/caravan will have varying stopping distances, and you cant make a blanket statement that it is a proven fact that you will achieve a shorter stopping distance when towing. And to be honest I would not use any stabilising device that had the potential to over heat my brakes. The only point that I am trying to get across is that it is far safer to allow for an increased stopping distance when towing, I think that makes sense for all concerned.
Allan.
If you read back through the posts Berty think you have missed some of the points that have been made with respect.
Allan
We don't actually know that Lutz device will cause over heating, the thermocople may be a warning as Drum Brakes tend to over heat and fade under extreme braking.
If constant or extreme braking caused fade before the anti snake device was needed the thermocouple warning would advise re degraded operating abilty of the anti snake device.
Allan, sometimes what you post doesn't make sense.
"And to be honest I would not use any stabilising device that had the potential to over heat my brakes". Overheated brakes and brake fade is caused by prolonged braking over a long distance. Surely you know that?
"No the peak of insolence is your very dangerous and misleading advice in the first place, from a man who admits that he needs a buzzer to warn him when his brakes on a towed trailer are not working........... I rest my case". The buzzer was supplied by a third party, doubtless a specialist firm. It is approved by the German authorities. If a car suffers from brake fade then it is pretty obvious to the driver. But if a caravan suffers in this way, it will not be obvious at all.
"You should never ever put yourself in a position where you suffer from brake fade, and if you do, that is down to poor driving technique". So that rules out all journeys that cross the alps then ........ or any long and steady hill in hot weather? Are we all restricted to towing in Holland now then?
"The only point that I am trying to get across is that it is far safer to allow for an increased stopping distance when towing, I think that makes sense for all concerned". There is no argument against this suggestion - of course it will always be safer to allow for an increased stopping distance. Lutz's point is that braking distance is not necessarily longer when you are towing a caravan.
"... for a person called Lutz, who for the majority know very little about him". We judge Lutz by his advice given, which over the past couple of years is pretty good. Have a look at his website - he has a long pedigree in the motor industry. And you Allan? You seem to be a bit of a bully. Give Lutz a chance to respond. We don't even know which country he's in at the moment.
Allan, I would never argue the fact with anybody that you must leave a safe braking distance with any vehicle be it solo or towing.
I do however resent the fact that you think the article was a figment of our imagination, and as I stated earlier on this thread I have no doubt when Lutz returns back to Germany from the UK he will provide a link for us all to read it.
Regarding the electronic stabilizer I do know a bit about as Practical Caravan itself ran an article on this device back in 2005, written by Doug King if my memory serves me correctly.
The summary of this article was that it was certainly the most effective stabiliser available and could solve the problem we currently face of caravans becoming heavier as it would make towing at over 100% safe. The two major chassis manufacturers Alko and BPW are working with similar technology to incorporate in future chassis design.
Could I also urge everybody to keep this thread courteous.
Firstly, Allan, I am not the source of the information. I have just passed information on from another source which, although you have the right to question, cannot be dismissed outright.
Secondly, the warning buzzer is intended as an indication of brake fade only and brake fade occurs neither during a one-time emergency stop nor during one-time deployment of the electronic stabiliser in the case of a snake. (The electronic stabiliser releases the brakes again automatically when the outfit recovers stability.) Hence, it has absolutely nothing to do with the subject in question, i.e. whether a car will come to a (single) stop quicker with or without the caravan in tow. The warning device is only an added feature of the electronic stabiliser but not an essential part of it. The only time that I have experienced the buzzer going off is during long alpine descents using engine braking only (on the car).
Thirdly, I will probably not be returning home until Easter so you'll just have to be patient.
hello allan,sorry its been awhile been busy,read your much earlier thread,-weight and braking distance.dont mean to be picky but the stuff you relate to is antcient technologie.i apprieciate they,ve got abs, so what.abs is old hat.and i dont know why but you keep refering to locking trailer wheels at junctions.these air systems are not working correctly.this is a defect.you refer to organisations for specs and details,but where do you think they get their info from?and from the way you talk i dont think you,ve grasped the scenaro of prop braking.it sounds though you expect things to be overbraked unladen.i do appriecate your experiance in the seat but A series erfs and the like are now gone.
Oh dear I bow down to the mighty knowledge of a handful of people on here.
In the Interest of health and safety I will repeat what I have said many times and reading the comments on here reinforces them.
1 compulsory driver training.
2 A towed caravan is the most unstable vehicle on the road, in certain conditions.
(Otherwise why would we need stabilisers?)
3. If you are a considerate, competent, & above all else a safe driver, do as all the major motoring organisations advice and increase your braking distance when you increase the weight of your vehicle.
But judging by the attitude of a minority of the people on here it will fall on to deaf ears, and I'm a bully? Just because I dare to voice my opinion against those who have been on here for two years! And can't be proven to be wrong on any topic. Most probably members of the same band we see hurtling off down the motorway at 70+ with van in tow, because they know better than any one else, how do the police phrase it, "They never listen" Well all I can now say is listen as well as you hear.
And finally moderator please step in and close this thread now, it has more than run its Corse.
Apart from the fact that the weight of the vehicle is not increased when towing, I have absolutely no issue with any of those statements.
This thread has largely been moderated from within. When people have started to get personal, then others have stepped in to remind us all of the forum etiquette etc. I can't see any reason for it to be deleted. I am patient enough to wait until Easter for a link to or the text of the article.
I don't "bow down" to Lutz's knowledge, but I have a huge amount for respect for someone who has been involved in engineering for longer than I have been alive, and who has probably towed 10 times the distance that I have to date. Not to mention the fact that his standard of English is better than many of us Brits. I think I can say about 6 words in German ...
And no, I'm not the founder member of the Lutz fan club. I just think that credit should be given where credit is due - Lutz has helped a great many people on this forum, me included.
