On or off?
Sep 23, 2023
1,335
578
2,435
On the switch it's supply in.and load out.if it's got three positions in general it's on,off,on,if it's a two position switch but a neon light it with have an extra terminal.thats to say three terminals in all,a supply in,a feed out for the load and the extra one for the neutral for the neon return (-) 🙂
5,285
See the photos of the stripped down switch. Just a simple on off single pole
Reactions: toad a caravan
5,285
I thought your problem was it was on when it was showing off sorry 👌
Yes it is just that.
Clearly they have been incorrectly assembled at the factory. Ian explains how it can be corrected. I tried it on an old one. Unsuccessfully.
You need a watch makers vice and tools and magnifier. What if after I had “fiddled” with it it caused a fire?
5,285
Eureka!
Prima Leisure have reacted swiftly and resolved the problem👏👏 Here’s their latest reply. It is reassuring they took this issue seriously and found a resolution.
Their positive action is to be applauded in this day and age of customer care.👍
It seems their suppliers/ switch manufacturer incorrectly assembled the switches.
Good morning
Thank you for your email.
We are currently checking the stock to see if this is an error from our supplier, in the meantime we have switched around the switch on two of them and will send these out 1950889 - due to dispatch today.
Kind regards
Elliott
Info PRIMA​
Customer Support Team​
Bailey Parts​
t: 0344 326 4000​
a:​
Unit 600 The Quadrant​
Bristol​
BS32 4QA​
Reactions: Mel and Hutch
8,984
Eureka!
Good morning
Kind regards
Elliott
Info PRIMA​
Bailey Parts​
t: 0344 326 4000​
a:​
Bristol​
BS32 4QA​
Good outcome, surprised though that they switched the components around in this day and age.
5,285
Now you know why so many display caravans get canaballised at dealers for workshop supplies🙀
I ‘m confident as a Major manufacturer these guys know what they are doing😉🤞
3,495
Do suppliers never check incoming products these days, even just by sampling? They could have pre-empted the problem if they had.
8,984
Manufacturer of caravans or switches. I read it as if Prima did the change. Given neither spotted the error ……Uhm.
I’m not at all impressed by the customer service given in your post #49 they were advising the customer to swap the wires. Come on now just supply the right parts chaps.
5,285
“Major Manufacturer” was Bailey who are Prima Leisure. Their staff did the changes.
The oem was probably somewhere along the Silk Road.
#49. A real worry🙀. But then Clive we are used to this as caravan owners😜
4,302
Eureka!
I fully appreciate we all make mistakes from time to time and the supply of the faulty items was not a deliberate or intentional action on the part of the supplier, but it highlighted a company failing which if they had a fully operation quality management scheme in place, the chances of theis failure reaching a customer would have been almost zero.
So the company has failed in one of its primary duties of care towards its customer.
The second failure occured when you reported the fault, and it was handled by an incompetent person. Anyone with the remotest smattering of electrical knowledge would know that an SPST switch is either open or closed, and the the order of the wire connections would make no difference.
It has needed a third action by you to contact the company to escalate the issue. If they had employed a competent person to answer your first contact the problem should have been fully sorted then. Instead it has cost you extra time and effort to resolve the issue, but it has also cost the company probably another £20 or so pounds to answer and escalate your issue on components that probably cost them no more than about £1 each!
What your comment actually shows is how bad the industry is at dealing with product problems. If you are happy with needing to make two extra contacts with a business to sort a simple problem out WHat does it say about the rest of the industry.
There seems to be no will or intrest in the industry that shows the industry is really ready to comply with the CRA's requirement that customers should expect fault free products. The industry has not learned the lesson that doing right first time is a far more profitable approach, and it engenders much better customer relations which would reduce their after sales costs by a very significant margin.
Applause for the actions in this instance is simply reinforcing the present abysmal quality status quo.
If organisations were to stop trying to get "positive feedback" they could redeploy the feedback staff in actually improving customer services or even better, deploy them to man a proper quality assurance process.
Companies can learn a whole lot more from fully understanding complaints than counting positive feed back.
5,285
Good post Prof.
But one small point . The guy dealing with the problem did follow procedure and referred it upwards only to be knocked back. He then listened to my next post and pressed on internally. He could have filed it. So imo he did make the effort. If I ’d heard no more I may well have set up a watch repair desk and had a go at Ian’s solution🙀
Roger’s point is the most important. Who is responsible for testing the efficacy of the bought in products? Gas appliances etc🙉
