Porta Potti help
Aug 16, 2020
I’ve been gifted a Porta Potti 165. The blade won’t close and seems to flapping around inside the waste tank. I can’t work out how to fix it. Any ideas
I’ve added a photo (the outside is just mud, not sure about the inside But can’t be bothered to clean it if it’s no good.
635
57
18,935
My recollection is that the front handle was pulled and pushed to open/close the sealing blade - usually black - that therefore slid from front to back. You might be able to see more if you rotate the spout 90+ degrees where the bayonet fitting aligns and can be removed.
Helpfully there is a full manual available here:
Aug 16, 2020
I’ve managed to get the lip seal out so I can see better, but can’t work out where the blade should sit
ASK THE COMMUNITY
