Whale water inlet with ic controller issues
May 21, 2007
12
Hello
So (from the outside) when you remove the blue cover to fit the service kit there is a white washer plunger spring and a top hat washer does anyone know the correct way this goes together and where the little top hat washer goes and which way ?
Ive changed everything yes everything apart from this white plunger thingy all sent by whale FOC (thank you whale) the pump still runs and don't turn off, no leaks etc,
I feel that its something to do with the plunger because if I follow the below test when I push a pen into the spigot I don't get a click its solid ? and when I
Connect left wire to left connector on the socket middle wire to middle connector the pump runs and it shouldn't
At the socket take a photo of the wiring from left to right on the IC controller
Remove the wires
Remove IC controller
Switch on pump at panel
Pump should not be running
Open the Kitchen tap at the cold side
With the flat end of a pen gently push the plunger into the spigot on the socket
You should hear a click and pump will start running
Release the plunger and pump should stop working.
If the pump didn’t start/ stop the microswitch will need to be replaced
I am probably going to buy a complete new unit but without the IC controller as its just a pain in the ass.
Any thoughts as ive gone water inlet blind now
Dec 27, 2022
628
452
2,135
Bin the IC controller, I had one fail replaced it still nothing but trouble with pressure and switching.
Replaced the whole intake with a manual one. Since doing that no problems at all.
3,676
Long time ago I bought an electronic pressure switch, from a small outfit in the Midlands, which has worked faultlessly for nearly 3 decades - they no longer supply caravan electronics, having specialised in the leisure boat industry - I have a couple of original manual pressure switches in my toolbox - just in case!
Apr 23, 2024
542
444
1,135
Hang on, you mentioned the ES6001 , when looking at that on the web thats the simple whale pressure inlet with the pressure switch built in , not the IC unit (which IMO is the problem unit) which is the ES8000 unit.I think you may have misconnected the unit.
I have one in stock so will look at the assembly tomorrow
