- Nov 16, 2015
- 12,580
- 4,731
- 40,935
Remember it depends on if your measuring the jockey wheel or the hitch load.When I was taking the reading it was only measuring the hitch weight
How will you know?Picking up the caravan today, so will see how this all pans out, if it’s a dud and the weight is well out, then it’s going back.
Jockey wheel will be about 1 ft behind the hitch. It will give different weights. Due to the moment arm from the center between the two axles. It gets complicated.Remember it depends on if your measuring the jockey wheel or the hitch load.
I’ll feel it in ma bones! 😂How will you know?
Every weighing device will have some error, and unless you have the device professionally calibrated you have no idea of how big the error of your device actually is.Ok now home from 3 weeks at work, and opened the yellow Reich Scale
Just out of curiosity, as this device has ‘sensitive sensors’ below, then why when I stand on the scale in the kitchen it reads 114kg
Yet when I stand on my bathroom scales it reads 95.6kg, and these aren’t some cheap Argos £10 scales
Should this be normal, or am I looking at this wrong?
Way too complicated for me to work out. I guess you could weigh both with bathroom scales. First under the jocky wheel, then under the hitch supported on a stick. You'd have to make sure the hitch was exactly the same distance from the ground in both instances, and take into account the weight of the stick.Jockey wheel will be about 1 ft behind the hitch. It will give different weights. Due to the moment arm from the center between the two axles. It gets complicated.
Maybe you will now realise why we sent out Reich back as we found it to be too inaccurate and too complicated for my little brain.I’ll feel it in ma bones! 😂
I’ll see how it goes and report back here, depending when I can get a chance to confirm on flat ground
Thank goodness, I am a Scot and an Engineer, It makes Mechanical things easy. 🙂Maybe you will now realise why we sent out Reich back as we found it to be too inaccurate and too complicated for my little brain.Strangely the Reich nose weight gauge was almost spot on by about 1kg.
yesWould it make a difference if the jockey wheel is pointing backwards or forwards?
Negligible difference, maybe an ounce or two so not even worth worrying about.Would it make a difference if the jockey wheel is pointing backwards or forwards?![]()
Your right, it gets complicated.![]()
My Reich scale was solely for twin axle? Are the newer ones for both single or twin?Wow, your getting my Grey cells going early this morning.
Set the unit for "Caravan Twin axle" when the hitch flashes press the center button and the two upper wheels ( left side) will flash, roll both wheels over the unit, it will store the combined weight of that side.
Press the center button again , lower wheels will flash, roll both wheels over again, it will shown combined weight again.
Press total and it will add left and right side together.
I would take a note of the left and right hand side down on paper just to re assure yourself.
Good luck.
I think that the one I bought way back in 2012 was twin axle specific, but I am probably wrong. LOL!Mine is very old, single axle Twin axle, both with or without nose / hitch and also Motorhome/ car settings.
Sometimes it can be Operator Error. 🤔I think that the one I bought way back in 2012 was twin axle specific, but I am probably wrong. LOL!
Cannot remember, but I thought both wheels on one side went onto the the pad at the same time and then adding the two sets either side together plus the nose weight, it calculated the weight of the caravan. Either way, we found it to be rather inaccurate so sent it back.
The big give away was the nose weight was wildly out and I think the calculated weight was about 100kg out. We had weighed the caravan on a weigh bridge a couple of weeks previous.
I must admit that was the first thought that cross my mind, but after doing it 3 times and every time a different reading I was not impressed. The nose weight on the caravan was reading under 90kg when I knew it was actually over 100kg as I double checked with our Milenco gauge.Sometimes it can be Operator Error. 🤔
It is horrible, when you check things several times and still get the same result, and you then find it is the unit that your using that is wrong.I must admit that was the first thought that cross my mind, but after doing it 3 times and every time a different reading I was not impressed. The nose weight on the caravan was reading under 90kg when I knew it was actually over 100kg as I double checked with our Milenco gauge.
When I get an issue like different readings, after some swearing and cursing, I leave the issue for a short while and do something else. I then go back, re-read the instructions and attempt the solution again as hopefully my head has cleared a bit.It is horrible, when you check things several times and still get the same result, and you then find it is the unit that your using that is wrong.
Done it with a multimeter getting wrong readings, internal battery was duff.
