Did i read that right Grumpy, you're refilling non-consumer refillable Gaslight cylinders on the forecourt ?
I had the impression that the grumpy guy doesn't understand what this forum is about.Is it only me that thinks "Grumpy" is/was a troll account?
Why thank you kindly πProf, Don't get "Grumpy", mistaken for "Mr Grumpy".
I'm sorry Mr Grumpy...I have edited an apology and correction into the comment.Prof, Don't get "Grumpy", mistaken for "Mr Grumpy".
Very kind of you but I've got thick skin so don't sweat it πI'm sorry Mr Grumpy...I have edited an apology and correction into the comment.
My advice is ignore calor and go with Gaslite. You can find them in B&M, any remaining HomeBase and some independants. I have one 5kg and one 10kg. They use the clip on tail, you can see how much is left in them and the bottle its self is light weight.Thanks for the welcome all.
Main decision at the moment is which Leisure battery. We will probably only use the van with a electric hook up but do have X4 motor mover so am I right in thinking a Grade B with 110ah would be ok? If soz any recommendations?
Have been given an empty 6kg propane bottle by a friend but seems like the gas bottle to exchange is still hard to get hold of. Any North West know if somewhere decent to grab one?
Sure I will have lots more questions but thanks again for the welcome!
He seemed to have set out to try to ruffle some feathers, he commented elsewhere that he'd probably be thrown off the forum, but he's apparently flounced off after I tried to offer an explanation of the legal constraints that this forum is bound by.
Grumpy is welcome to use this forum , but he needs to calm down a bit. π
The criticism that came your way related to your practise of refilling gas cylinders that are not designed to be refilled my members of the public at garage forecourts or other non authorised places. Whilst you may have sufficient experience to get away with it, such dubious practices could encourage someone with a lot less experience to do it, snd get it wrong resulting in a safety incident or worse. Such practices as your could actually lead to outlets refusing to let cylinders be refilled thus placing restrictions on those who use cylinders such as Safefill. or Gaslow being refilled by themselves. Practical doesnβt equate to stupidity.As I am taking so much stick I thought I should reply.
Grumpy thought the words PRACTICAL (of or concerned with the actual doing or use of something rather than with theory and ideas) Caravan was a place where practical
people could discuss real world issues no gobbledegook theories and ideas, Grumpy was wrong.
I am not a troll only a practical man who is very calm, but fed up of 50 years of very hard work listening to "experts" who think they know everything because they have read a couple of books.
If you want to know about something, do it, don't write about it, and think you know it all.
So legally you are responsible for what I write on a blog, Is that correct?
Yours very calmly
Grumpy
Yours very calmly
Grumpy
Calor's concern at unlawful and dangerous refilling of LPG cylinders at petrol stations I Calor Press Center
LPG (liquefied petroleum gas) supplier, Calor is extremely concerned at the reported rise in the number of people filling up gas cylinders using autogas dispensers at petrol forecourts.www.calor.co.uk
Flogas investigation exposes illegal gas cylinder filling | Flogas
Flogas Britain, one of the UK?s leading liquefied petroleum gas (LPG) suppliers has won a major victory in the battle to stop the highly dangerous practice o...www.flogas.co.uk
HiGrumpy, I cannot help but think you are, in the most modern terms " click baiting" people, the building of aircraft and helicopters by yourself , mostly interest myself. The gas bottles are another item.
I will follow your interesting postings.
Hi Tobes, I hope we are not confusing NWN , between Calor lites and Gas Lights.My advice is ignore calor and go with Gaslite. You can find them in B&M, any remaining HomeBase and some independants. I have one 5kg and one 10kg. They use the clip on tail, you can see how much is left in them and the bottle its self is light weight.
Yes I can understand your way of thinking it COULD actually place restrictions on people who use Safefill.
I cannot comment on Safefill but I will buy one and test it. From what Ive seen on the internet the quality of the bottle and one way valve look a bit suspect, but I won't say much until Ive purchased one. If I'm am in any doubt about the quality I will throw it away.
Another of my pet hates is people who comment on an item and have never owned one seen one or touched one. I have spent a lot of money buying things just to test them before I give my opinion.
The one way valve system I have seen is very substantial and proven by BOC.
The other item you mentioned, Gaslow, I have no idea about so will not comment.
Talking of stupidity have a look at the terrified Manon you tube fitting a pipe to the outside of his motorhome, It is unbelievable
We have not experienced any fault or with refilling themissues with either bottle, but I can understand your take on people commenting about items that they have never tested, used or even seen.
The key issue is that the bottle has to be designed to withstand the pressure of whatever is stored in it, as Prof said propane bottles run at a much higher vapour pressure internally, which is why propane works in the cold and butane does not. UK automotive LPG is majority propane and I would assume a Safefill is designed to withstand 100% propane vapour pressure given that the suppliers are at liberty to provide whatever lpg mix they want. Not necessarily the case for a butane cylinder. Itβs the possibility of an unregulated high pressure connection from 100% propane into the butane cylinder that would be the worry,I am not sure even if it is possible to feed butane and propane into the caravan system through the bulkhead regulator at the same time which is why I incorrectly assumed my post would be understood.
We use LPG when refiulling our Safefill cylinder and this is a mixture of Butane, Propane, propylene, butylene and isobutane so not sure why Propane and Butane cannot be mixed anyway? After all they all come from the same source.
A classic example being the ONR who legally licence the whole lifecycle of a nuclear plant from initial design to decommissioning. The various national aviation authorities too, will licence without owning, testing or operating aircraft.Then again, as so often in my profession, I, my team and later as a consultant had to evaluate what equipment was selected for our products and my clients.
We, they, can't physically nor financially purchased every option out there so undertake varying depths of analysis. Many items I can assure you don't need much consideration to realise they are substandard, both in themselves and relative to their competitors.
It is quite nonsense to suggest you have to own, used or have physically tested something to hold a very valid opinion of it, its quality or have adequately research its reliability.
TBH I thought we were discussing caravans and not nuclear facilities?A classic example being the ONR who legally licence the whole lifecycle of a nuclear plant from initial design to decommissioning. The various national aviation authorities too, will licence without owning, testing or operating aircraft.
I was supporting the comments in the above post 114 by JTQ who was commenting on a Grumpy post, that you need to have owned, operated, or physically tested something to be able to hold a valid opinion on it. I see absolutely nothing wrong with using two examples where safety is important and which are in everyday use, but their licences will have been granted by organisations that do not meet Grumpy's criteria.There are numerous other example too in the real world that we live in, but from caravan examples posted in a different thread where main panels of new caravans are failing perhaps the makers 'practical" knowledge isn't doing the job.TBH I thought we were discussing caravans and not nuclear facilities?
However not baseless if you have used, tested or seen the item. In other words you are just passing an opinion and not fact. However the thread is about Calor gas and not nuclear etc options.It could be that if the "minds" of those charged can get round all the nuances in something as complex, then twigging what these might amount to in a Safefill bottle valve, as was raised here, or even a caravan, might not be too challenging?
Just pointing out the baselessness of claiming you have to own, used etc a product to make a valued comment about it.
Thank you very much for a REAL WORLD hands on view of something you know something about. I think its best not to put my findings on here when I purchase and test one.We ar eon our second Safefill bottle in 10 years. I first one was a 10kg bottle but we had to sell it has the fit into the locker of the Buccaneer caravan was too tight and also awkward.
